Results 1 to 2 of 2
    Default crossover questions??
    Hi I need to make the best crossover I can for my
    two way design. I want to put the tweeter on one
    wood board and the midwoofer/woofer on the other
    so there is on crosstalk.I want to use a 6db
    crossover so it uses not alot of caps or resisters
    if I spelled that right. IF they are both 8 ohms
    do I need to buy a mills resister or can I leave
    it alone? Also If i raise the ohms for the tweeter
    is it brighter or softer? I heard this can make it
    or brake it. Same question for the woofer as above.
    I wanted to buy a woofer tester 2 but, thought
    will it really make that much of a diffrence in
    sound? I also need a crossover program and a box
    model programe like cat. The cat program does not
    have what I want. I just want to make it sound
    right so I not have to fix it later. I thought of
    putting the crossover outside the box on its
    own little box between the amp and speaker box
    I have seen a couple speaker companys do this just
    in case they have to fix it or replace it with out
    tearing the box apart. Is this o.k. or will it
    hurt the sound? Also is there a diffrece in caps
    sound like, oil,cotton,bees wax,or tin,gold,silver
    is it really worth that much more to pay for the
    caps. Is it a 10% ro a 80%. Thanks jm
    Cleveland, Tennessee
    457
    Default Re: crossover questions??
    > Where do I start. No need to split the crossovers as crosstalk should not be an issue.
    Don't count on a 6 db crossover doing the trick.
    Pad the tweeter with a series / parallel resistor to keep impedeance the same.
    Crossover location will have no effect on sound.
    Personally I fond no noticable difference in cap's. Others will say I am nuts but I thenk many agree.
    Check out this sight fo a little help on circuits and box options. mhsoft.nl/spk-calc.asp
    Good luck
    > for my
    > one
    > other
    > resisters
    > ohms
    > leave
    > tweeter
    > make it
    > above.
    > thought
    > in
    > box
    > does not
    > sound
    > thought of
    > box
    > this just
    > with out
    > it
    > caps
    > tin,gold,silver
    > the
