Results 1 to 8 of 8
    6,251
    Default Dayton Home Theater
    I have built the DHT from Wayne J. site, but modifed the front baffle to create a tower speaker design, insted of the bookself design. I have not flush mounted the tweeter, yet. I think that they sound good, but I am able to "hear" were the sound is coming from, insted of the sound filling the room. Could this be from the fact that I altered the baffle size or the lack of flush mounting the tweeter? Currently the woofer and tweeter are in parallel would a reverse on the tweeter polarity fix this? Any other suggestions would be appreciated, thanks.
    (Originally posted by: Bryce)
    Default Re: Dayton Home Theater
    May be this tweeter is very directive ! Try a ring of felt around the tweeter and if you are listening at equal distance from each speakers, try to toe the speakers inside. (Left speaker firing a little to your right and the right speaker to your left) It could be the front gear too, What is running the speakers? Good luck!
    6,251
    Thanks for the advice. The tweeter is the dayton titanium dome. I will try the felt and flush mounting. I am running them from a KLH all one one amp and DVD player with maybe if I'm lucky 15 watts (i know it's not ideal but I will be upgrading to a yamaha receiver with amount 100 watts which should help out quite a bit).
    It won't help, it will fix most of your problems !!! anyway if it dosen't, just ask again
    6,251
    Check the polarity and the crossover wiring first. Although not flush mounting will cause a small offset in phase, it should not be significant enough to cause easily audible change in frequency response.
    (Originally posted by: James Lee)
    I am currently working on a design using
    Dayton/vifa drivers.
    I noticed you said you built these from the Wayne J. site. whats the address.
    Tks.
    Blaine
    p.s. I'm building a set book shelf speakers into towers also.
    I just hope I don't build them bigger than their britches!
    SW BC
    380
    DePere, WI
    4,250
    I'd try placement, first. Try using a little toe-in or separating them, or bringing them a bit closer together. I had a full set of the DHTs once upon a time, and while they were kind of "forward", they did a pretty decent disappearing act.
