Results 1 to 20 of 35
    Default What amp shall I buy?
    Well I thought I would come on here and ask you guys another question.
    I am probably about to buy a new power amp or monoblocks and I just wanted some input.
    The power amp that I am looking at is a Mark Levinson No. 332 dual mono power amp with 200wpc into 8ohms
    OR
    The Bryston 7B ST monobolcks that pump 500wpc into 8ohms for slightly more cost.
    Farmington, CT
    609
    Default Re: What amp shall I buy? *PIC*
    Come to DAYTON or DC to the diy's and hear my Nelson Pass Aleph 2 monoblocks
    100 wpc into 8 and 160+ into 4 FULL CLASS A
    -Matthew K. Olson
    I would pick the amp with the most power
    output. 500W @ 8 ohms is nice. 200w or less
    @ 8 ohms is boring.
    Wish i could go, im pretty sure that the Levinson is 200wpc class A into 8ohms b/c i know for sure that the No.331 is 100 class A into 8ohms
    Im pretty sure that the Bryston 7Bs arent class A
    I really want class A but 500wpc sound pretty good for designs that might be really inefficient.
    what would you pick out of the two
    BTW if i bought the 7B's the would have seperate small hardwood stands off to both sides of my audio rack
    > @ 8 ohms is boring.
    Im pretty sure is 200wpc of class A, usually that means it can do more but then switches to A/B amplification, could probably do 300wpc or so.
    but
    if the 7B's were powering a 4ohm load i think there rated for 700wpc which would be totally insane.
    Default Go With Levinson
    The mids will be much more "fleshed out"; richer tone color all around.
    The Bryston's very, very nice, but much cooler presentation.
    > 200wpc into 8ohms
    > OR
    Take your pick, your in pretty high-end territory there and I'm sure they both sound fine. The Levinson should heve plenty of power for almost any application and seem to tolerate most any load. They aren't true Class-A in the traditional sense though they seem to consume more power at idle than normal class A/B designs.
    I've listened to the Brystons and can't think of a reason not to buy them. Tons of power for pretty much any application. They probably aren't stable down to 2ohms like the Levinson but under most conditions that shouldn't really be a problem. Add in the 20yr waurantee and I can't see a reason I wouldn't get them. O yeah, there's the matter of getting my wife to agree. . . . oh well :-)
    I have no wife, only a girlfriend that cringes every time I spend money on new audio equipment.
    Stittsville, Ontario
    1,969
    > audio equipment.
    At this power level, you SHOULD be looking at pro audio amps. I traded my Bryston 4B for a Yamaha P3500s. Both are class AB...No audible sound quality difference to me.. but everybody's ears are different. The Yamaha has more power for half the price.. and if you're worried about fan noise.. forgetaboutit. I have run this amp at just under clipping levels on dual 15 subs(4ohm load) for 4 hours straight, and it never got hot enough to turn the fans on!!! These things run cool.
    Minnesota
    258
    > 200wpc into 8ohms
    > OR
    <A HREF="http://www.marklevinson.com/downloads/manuals/no332.pdf">http://www.marklevinson.com/downloads/manuals/no332.pdf</A>
    <A HREF="http://www.bryston.ca/pdfs/7bsst_spec.pdf">http://www.bryston.ca/pdfs/7bsst_spec.pdf</A>
    Well getting to the nutz and bolts of it all. Just by spec the Levinson is the one to go with.
    It has a higher damping factor and lower output impedence. Is Class A all the way. The Bryston starts out in Class A at lower power levels then goes to Class AB.
    Brytson is good stuff for the money , but if you are getting a 332 Lenivson for cheaper, you would be a fool not to get it.
    Most any speaker system thats worth its own, at 200/ch@8ohms will blow dry your hair nicely.
    I like my Aragon, but if I had a choice in all three types we'll say. Levinson for sure.
    The 332 will reveal weak chains in your audio system, it is that good.
    Good luck happy listening
    Default Real Power - or - "Pro" Power
    Is it rated under FCC accepted RMS guidelines: ie., pre-conditioning, power rated across the audible spectrum, 20hz - 20Khz, both channels driven(except for monoblocks, obviously), with a specific distortion rating, as in:
    200 watts, 10hz to 20,000 Hz, at no more than .01% THD
    Or, the way the pro jobs do it:
    500000 watts at 1khz, 1.0% THD, for 50 milliseconds prior to total clipping.
    That 500000 pro watts shrinks down pretty quickly under more stingent FCC RMS measurements.
    1,969
    Default A fool and his money are quickly seperated!!
    Frankly.. when it comes down to it, I don't care how an amp is rated. I did a head to head double blind test with the Bryston and the Yamaha and I liked how the Yamaha sounded better.
    Always listen before you buy.. I broke this rule when I bought the Bryston.. on reputation alone.
    > inefficient.
    I use high powered amps with high sensitivity
    loudspeakers, to me that is a great recipe
    to replicate live performance. Bridged amplifiers
    are great for this, not which amplifier class
    is used provided the amplifier is well designed.
    Default Re: Real Power - or - "Pro" Power
    Pass Labs rates their amps the same way,
    1khz, 1% THD .. must be a bad amplifier they
    make .. /// lol ///
    Default Yes, Indeed They Are
    It's foolish to claim that one amplifier is more powerful that another, when it may indeed be LESS powerful.
    If you're chosing on the basis of power, than you MUST compare like measurements to like measurements.
    Otherwise, you're a FOOL who's just been sold a lot of hot air, as in
    "Sure, buddy - Why this amp has 10 million watts. You betcha".
    Default Good - Bad - Ugly
    My post was specifically about power comparisons. You have to be an idiot to be willingly fooled.
    If you're making judgements solely on power alone, you must compare like measurements. Comparing at 1Khz measurement to a full spectrum measurement, and then confidently proclaiming the former as more powerful is to be willingly sold a bill of goods.
    Hey - I've got a bridge for sale. Really.
    North TX
    1,978
    > than .01% THD
    > measurements.
    It's "FTC" requirements. And it's not *quite* that bad. A "200 watt per channel" audiophile-grade amplifier and a "1200 watt" pro amp (that is 280 wpc/1KHz/8 ohm, 600 wpc/1Khz/ 2 ohm) both put out the same real world power, sound very similar unless the pro amp is current-limiting, and both operate off the same 55-0-55V, 600 VA transformer. Except for the very bottom of the barrel, pro amps will pass the FTC burn-in requirement at 8 ohms per channel (the better grades will do it at 4 ohms, and some of the stupid-expensive stuff will pass at 2 ohms). Most any audiphile amp worth it's stuffing will pass the FTC burn-in at 8 ohms, but you would be hard-pressed to find any audiophile amp that will pass the FTC burn-in at 2 ohms (at ANY price).
    Default And, Pass Amps
    And, yes, I've heard Pass amps and I like the sound.
    But, as I said, I was speaking of making meaningful, like to like numbers comparisons.
    The fact that Pass chooses to print a 1khz spec doesn't say anything about it's sound; only that it'll be difficult to compare it's power rating to another amp differently rated.
    Obviously, pure class A amps aren't going to be as powerful as class AB, and certainly as class B, D, etc. So, it's distressing that Pass is choosing to spec in this manner- but, obviously folks aren't looking that closely the the numbers these days.
    Finally, I have no wish to get into a war on this issue with you - or anyone. I just think that it's common sence to compare apples to apples.
    Default If it were me...
    ...I'd go with the Brystons. Not to knock the Mark Levinsons, but I've *never* heard of an unhappy Bryston owner. Come to think of it, in 17 years running the maintenance shop here, I don't recall an instance of a failure on one. Even in heavy pro use they're unkillable. And the SQ is up there with anything else on the market, at any price (sorry, Matt.)
    Just my .02.
    Bill
    > into 8ohms
    > class A
    > inefficient.
    Default Not FCC, FTC
    The FCC could care less about audio equipment, as long as it doesn't radiate RF.
    The Brystons are even more conservatively rated than the FTC requirements. They will maintain rated power indefinitely without complaint. They will also take abuse no consumer amp could tolerate.
    The 7B is rated 600 watts into 8 ohms and 900 watts into 4 ohms. If you regularly need to drive loads under 3 ohms, you can order a special version of the amp that is designed for that.
    I think the 20-year warranty says it all.
    And I don't know where you get your concept of "pro job" power ratings; reputable first-tier pro amp manufacturers, like QSC, Crown and Bryston all rate conservatively; their users won't put up with that nonsense.
    Best regards,
    Bill
    > than .01% THD
    > measurements.
