Subwoofer Suggestions
I have been working on designing a powered sub for a friend to use for music and home theatre in an "average sized" living room. At first I had a great design worked up using the new Dayton RS HF 12 in a 2.7cu ft ported box but he wants something smaller. I plan on using a 500 watt amp. My best options at this point are:
- Dayton Titanic 10" in a 35 l box ported @ 22hz
- TC Sounds TC2+ 12 SVC in a 36 l sealed box using some low end boost from the amp
The Titanic beats the TC in max output below the mid thirties, it's ahead by 5 db at 20 hz. The TC beats the Titanic above there and is ahead 3db at 50 hz.
I am looking for any comments on these enclosures or suggestions for other drivers to look at. I have already tried all the new Dayton RS subs, and several other TC subs. I am trying to find a woofer in the $150 or less range.
Jason
Go
Provided Link: theNoid's DIY Raffle
Since you are going withthe 500-watter, get one of the 12: Dayton RS subs and build small sealed box for it. Then use the PEQ on the amp to bump up the low end. Small box, excellent SQ, much output.
Noidster
________
HelenHot live
Re: Subwoofer Suggestions
> ported @ 22hz
> less range.
> Thanks,
> Jason
That box for the titanic would be problematic because of the size of the box & tuning. Simply put, the port would not fit inside the box. Thus, you would have to put the port *outside* the box. The easiest way to accomplish this is with a slot port.
For simplicity sake, I'd go with the TC. With the 500W, it's definitely the more expensive. Just remind your buddy of the Iron la. He can have it:
1. Loud
2. Low
3. Small
Pick two. ;-)
I considered that one, I really like those new RS subs, but the output below the mid thirties would be less than the TC sounds sub and quite a bit less than the ported Titanic
Jason
> Noidster
Yeah, the port length is a problem there, I figured on a slot port, the low end output is very impressive for the enclosure size though.
I have gotten a real good understanding of Hoffmans Iron Law in the past week or so, the more boxes I model, the more I see it.
> 1. Loud
> 2. Low
> 3. Small
> Pick two. ;-)
