Results 1 to 12 of 12
    Default Qs about baffle diffraction
    In doing my homework for building my speakers I have come upon Roman Bs article (http://www.rjbaudio.com/Audiofiles/t...fraction.html)
    about baffle diffraction and had a question. I am looking at a 3 way design and I understand the baffle diffraction as he explained it, and the question is this.
    If the baffle used in my speaks is the 9" (just used as an example) like in Roman's article, I will have to worry about baffle diffraction in the upper end of the midrange as well correct? From what I can tell with a 9" baffle, diffraction will begin to occur at right about 1500hz, correct? Unless the mid is crossed lower, which seems rather unlikely.
    TIA
    Ethan
    Oct 2005
    16,595
    Blog Entries
    1
    Default Re: Qs about baffle diffraction
    Provided Link: Baffle diffraction simulator
    > TIA
    > Ethan
    Baffle diffraction occurs across the spectrum. You'll notice a drop off in bass response, but you will also get some "ripple" in response above that which is mitigated by rounding the edges.
    Download the baffle diffraction simulator to see what the effects will be for your design.
    Sep 2005
    Placentia, CA
    1,068
    I use John Murphy's formula, and diffraction for a 9" baffle starts at 503 Hz. For a full 6 dB baffle step compensation, assuming a 8 ohm system, the resistor is 8 ohms, and the inductor is 1.8 mH. May be the experts can chime in to see if I'm correct.
    Hong
    Sep 2005
    Chicago-ish
    1,546
    Confuse not baffle diffraction and baffle step.
    You speak of baffle step.
    Diffraction is, as someone else mentioned, something that occurs across the frequency spectrum. I pick up an interesting 1800Hz dip on my 14" wide (with 3/4" chamfer) 3-ways - felt alleviates this tremendously.
    C
    Sep 2005
    Placentia, CA
    1,068
    I stand corrected. Read the question too fast. Thanks Chris.
    Hong
    Sep 2005
    Canton, MA
    2,620
    Provided Link: Dave's Speaker Pages
    The other response are all good. If you are interested, I have a couple of sections at my web site specifically on diffraction as well as an article in the June 2005 issue of audioXpress.
    You will have a significant influence with a 9" baffle, both on the tweeter and the midrange. The woofer should be operating exclusively in 4-pi space (below the baffle step).
    Diffraction of the tweeter response due to the midrange or woofer will also occur. This can be as severe as that of the baffle edges.
    Just to clarify the post by cjd, baffle step is part of diffraction. Step is not just related, it is one of the aspects of diffraction.
    dlr
  7. #7
    Default The same phenomenon.
    > step.
    The smooth baffle step shown on John Murphy's site applies to a spherical baffle. It turns into a spiky slide with a rectangular cabinet face. Diffraction occurs all across the spectrum. And sound waves wrapping around the cabinet edges causes the step. But it's more pronounced in certain frequency ranges than others.
  8. #8
    Sep 2005
    latitude 40.8510 longitude -96.7592 altitude 362 meters
    3,925
    Default Re: Qs about baffle diffraction *PIC*
    Below is the modeled diffraction plot of a woofer on an 8" x 20" baffle. Note that there is a significant ripple dip between 450 Hz and 3K. Not only is the woofer affected, but a midrange or tweeter on this baffle would be exposed to substantial response variations due to diffraction effects.
    I used to assume that only the woofer and midrange was affected significantly by diffraction effects, but I have since found for flat mid/tweeter summation, baffle diffraction must be addressed.
    C
  9. #9
    Sep 2005
    Chicago-ish
    1,546
    Default Re: The same phenomenon.
    Well, yes. Ultimately, it comes down to the same physics.
    However, means of dealing with them differ as well as the impact (and obvious-ness to the listener). Baffle width will tell you the fundamental/harmonic points by nature of the distance(s) of course, and this relates to baffle step and diffraction alike.
    I think I'm tired though, as my mind wandered off and forgot where it was going just now. Re-reading this post doesn't help. :P 12+ hours at work, got home in time to sleep and get up for work today...
    C
  10. #10
    Ahh... I see! Thanks much for the input and that link! There is so much to consider when designing... wow.
    > design.
  11. #11
    Default 0.4dB dip above 2kHz?
    I don't see the tweeter being effected by that at all, as long as you have a xover above 2kHz.
    There IS a relative 2dB peak by 800 Hz. And a 3dB dip by 250Hz. THAT's an issue. I guess it depends on how picky we are.
  12. #12
    Sep 2005
    Canton, MA
    2,620
    Default Re: 0.4dB dip above 2kHz?
    > above 2kHz.
    You can't judge the midrange or tweeter by that graph. It's for a woofer only with its directionality included. The midrange and tweeter will be far worse.
    dlr
