Results 1 to 5 of 5
    Default component vs. composite cables
    What is the physical difference between component and composit cables? I know that they each provide different information, but they both use RCA jacks. Could you use three composite cables to get a compnent signal to the TV?
    TIA
    Default Re: component vs. composite cables
    The cables are the same, go ahead and use three.
    Dallas, TX
    2,750
    > three.
    Component video provides more bandwidth than composite. Composite sends the luminance and color information over one cable. Components sends Y which is the luminance or brightness component on one cable, plus B-Y which is the blue color difference on another cable, plus R-Y which is the red difference on another cable. Hence it takes 3 cables. Green does not need to be sent since it is derived from the B-Y and R-Y signals.
    The important thing to remember is that if you want to take advantage of high definition signals then you will need at least a component cable. It can transmit signals like, 480P, 720P and 1080I. A composite cable does not have the bandwidth to send anything more than standard definition television.
    Silver Spring, MD
    1,606
    Same with S-video. No high-def through anything less than composite. DVI and HDMI are better.
    > Dave
    Default Mix up the red, green and blue.
    > the TV?
    They are both shielded, 2-conductor RCA cables. Go ahead...and please tell us what happens if you get the red, green and blue colors switched around!
