Results 1 to 6 of 6
    Default Basic questions on speaker ports (my post #2)
    A continuation in my series of questions on my first speaker project (Modula MT)…
    I’ll make the ports from 2” PVC tubing and I’ll add a roundover/flare on either end.
    -Is a 1/2” roundover best or should I go 3/4”? (I have to buy a router bit either way.)
    -The port is supposed to be 7.5” long, so that includes the flares, correct? (1/2” flare, 6.5” of PVC, then 1/2” flare)
    -Where to put the port on the rear of the speaker? Some say anywhere, some say behind the tweeter. Does it matter?
    Thanks!
    -Jon
    5,874
    Default Re: Basic questions on speaker ports (my post #2)
    > way.)
    I've found 1/4" to be waaay better than none at all. Diminishing returns I think, plus MOST PVC has about a 1/4" wall, so you can round it over before installing it. If you're going to use a 3/4" r.o. on EACH end, then you'll actually be rounding over the cabinet at the front, and you have to make some kind of big wooden doughnut-thing on the back end so you've got material to round over.
    The way I do it is to figure the unflared portion plus ONE flared end (which is like averaging the whole thing - I guess). So . . .
    For a port that WinISD (or your plan) says needs to be 7.5" long, I'd make its TOTAL length 7.75 if using a 1/4" r.o., 8" if going with 1/2" r.o., and 8.25" if 3/4" r.o..
    With your 1/2" r.o. example, my overall port length would be 8", and my unflaired length would be 7" (8" - 1/2" - 1/2"). That averages out to 7.5 ".
    > Thanks!
    > -Jon
    Doesn't really matter. I vent out the top sometimes. I guess behind the tweeter (if rear firing) is suggested because tweeters are sealed so there's no back wave being generated there that could exit the port.
    Provided Link: Port Tube Installation
    I just wanted to add a point about porting: Anywhere is fine EXCEPT directly behind the woofer. That may be obvious to you, but I've seen others make the mistake. So, this is just a heads-up, if you didn't know.
    Also, the link below is a short article on port installation that might be helpful. It might seem to be a bit of work, but the finished product is really worth it.
    > 8.25" if 3/4" r.o..
    > 7.5 ".
    Right. I was planning on doing the roundover on the back of the actual cabinet. And also add a donut and some sort of support/donut/flare to hold up the inside end of the tube.
    > 8.25" if 3/4" r.o..
    > 7.5 ".
    Got it.
    OK, thanks.
    Right. I don't know too much about this, but I kinb of figured what you say to be the case- it just kind of makes sense.
    So how far from the direct rear of the woofer is OK? I thought it might be easier to have the port toward the bottom of the cabinet. But that would put it somewhat close to the woofer. Idunno, maybe just a few inches away. Maybe just going in the center, at the tweeter height is the wise thing to do here.
    Nice link, thanks.
    -Jon
    There's a lot of opinions on port placement. To keep things safe, I generally mount the port at the rear of the tweeter.
    > thing to do here.
    > Nice link, thanks.
    > -Jon
