Results 1 to 7 of 7
    Default Go
    Does anyone know if such project has been posted? or anything similar I can make and tweak from?
    ________
    Escape
    Jan 2006
    Sterling, CT
    3,450
    Default Re: rs125+bg neo project?
    Here is a design using the rs180.
    <A HREF="http://www.lonesaguaro.com/speakers/...7/Cryolite.htm">www.lonesaguaro.com/speakers/DaytonRS7/Cryolite.htm</A>
    Jan 2006
    Sterling, CT
    3,450
    Here is one using the rs180.
    Default Re: rs125+bg neo project? *PIC*
    Provided Link: My Main Speakers
    I am using the RS125 and Neo3 tweeter together, however, I'm doing it actively.
    I found that the lower the crossover the better it sounds, however, if you are wanting to do it passively you probably can't pull off the 1.8khz 8th order crossover that I'm using.
    If you want to use this without a subwoofer, I'd suggest going with the RS180 version.
    Default Go
    > tweak from?
    reply testing
    ________
    Gsr600
    Provided Link: RJB Audio Projects
    > tweak from?
    > AJ, thanks for the link. I vaguely remember
    > a project with the rs mid and bg neo.
    > However, I'm planning to make a rather small
    > bookshelf speakers for my gf, she's still in
    > dorms and I opted to go with the drivers i
    > already have.
    > Can anyone here give me some pointers on
    > redoing the crossover for the project AJ
    > posted?
    > I'm guessing the bsc (if there is one) needs
    > to be adjusted, also the level matching with
    > the tweeter?
    > Bryan Jackson,
    > I'm running all active at home too
    > But, this project needs to be passive.
    > Thanks for the suggestion.
    I have a few versions of speakers using the RS125 woofer with different tweeters on my site below. The Microbe and Microbe SE designs have a crossover point of about 3kHz. Under the Microbe project there is a link to the Microbe RS design which has a lower crossover point. You should be able to use one of the woofer filters from one of these designs and then just come up with a tweeter filter to match (a 3rd order electrical filter with some resistors for attenuation should work well). The best way to design a crossover without measurement equipment is to use the FRD consortium tools along with a crossover simulator like Speaker Workshop and I have some tutorials on how to use these tools under the "audiofiles" section of my site. Hope that helps.
    <A HREF="http://www.rjbaudio.com">http://www.rjbaudio.com</A>
    Jan 2006
    Sterling, CT
    3,450
