Results 1 to 7 of 7
    Default Vented or Sealed?
    Hey guys. I was wondering if anyone had input on which type of enclosure would work best for a sub that needs to play up to about 200hz. I have heard that sealed boxes tend to distort upper bass more than a vented enclosure would. Is this true? Thanks a ton!
    Default Re: Vented or Sealed?
    If you have a woofer designed to give you good
    sound quality in that region, either sealed or
    ported can be made to work well.
    > good
    > or
    How is a woofer indicated to be useful in this region? Q factors, size? Also, does tuning frequency effect the upper bass? I really appreciate the help!
    5,897
    Box type has the most effect on the bottom end of a sub's range, not the top. What woofer (exactly) are we talkin' about? Get WinISD (beta) at <A HREF="http://www.linearteam.org">www.linearteam.org</A> for box design info. The upper end of a sub's range (which 200 Hz would certainly be considered) if determined more by its responce curve(s). MY sub is only used in the 30-50 range.
    > the 30-50 range.
    The sub is the Tang Band 5-1/4" neodymium subwoofer. It is paired with small 2" drivers so it needs to get up a little.
    5,897
    > little.
    Closed, 65 Hz, vented 32 - that's what I'm talkin' about!
    You want to put this in a 1/2 cf box, with a 2"d x 11-1/2" long port. Line the box. Should sound awesome. Is it powered? Sub & 2 satellites?
    > talkin' about!
    > Sub & 2 satellites?
    Sweet, that does sound good. Yes it is powered. I have the Dayton 25 watter for the sub and a t-amp for the sats. Is there any way to shorten the port length? Thanks a lot for your help on this matter!
