Page 1 of 3 123 LastLast
Results 1 to 20 of 53
    Default Best cone midrange
    What would be the best driver to use in the 200-2500hz range that PE offers up to $120 a piece?
    any suggestions or experiences are appreciated.
    Default Re: Best cone midrange
    RS150 would do you fine, as would the rs125.
    Sep 2005
    North TX
    1,978
    > piece?
    > appreciated.
    294-652. My applications may be different from yours, however.....
    Sep 2005
    Kokomo, Indiana
    7,246
    Default Re: Best cone midrange *PIC*
    Provided Link: B&C Midrange
    > piece?
    > appreciated.
    In a home application this can cross that low. You might be surprised what it can do....
    Sep 2005
    6,251
    Peerless HDS Exclusive 830882
    Cost: $66
    Usability:
    Build Quality:
    Consistency:
    Zaph Audio : <A HREF="http://www.zaphaudio.com/5.5test/">http://www.zaphaudio.com/5.5test/</A>
    Comments: This is the 5.5" flagship of the Peerless line. It's touted as having low distortion, and it lives up to that. Harmonic distortion was near Scan Speak levels with the exception of some issues between 400 and 500 Hz. The 450 Hz peak in HD was exactly the same in both samples, leading to an extra star for consistency but holding back one star for usability. If I had to speculate on the 450hz HD peak, it's probably related to the dustcap-cone configuration. The frame casting was a little on the rough side, and the phase plug was not centered as well as I have often seen in Seas speakers. Overall, it's still a great driver and a good value but honestly I would have hoped for a little more attention to details.
    or slightly above your price range:
    Seas Excel W15CY-001 (Magnesium)
    Cost: $135
    Usability:
    Build Quality:
    Consistency:
    Value: Comments: This is Seas' definitive high end driver. Response within the usable band is flat line smooth, and harmonic distortion is excellent, though a notch down from the Scan Speaks and the Peerless Exclusive. The breakup node is easily controllable with a simple RLC notch, though I consider the optimum crossover point of this driver to be around 2kHz, maybe higher depending on how much that 2.3kHz 3rd order harmonic distortion bugs you. The 5th order harmonic at 1.5Khz is low enough to be off the audible radar. It's not the cheapest 5.5" around, but it's probably worth the extra cost. Note: a couple stars off consistency for a wandering breakup node over the years.
    (Originally posted by: Pinky)
    Sep 2005
    Injiana
    1,289
    Default What coloration are you looking for?
    <A HREF="http://www.partsexpress.com/pe/pshow...TOKEN=48034275">http://www.partsexpress.com/pe/pshow...TOKEN=48034275</A>
    That one would be 'great' for rock and metal..
  7. #7
    Sep 2005
    Pennsylvania
    602
    > do....
    Jeff:I have had my eye on that one for a long time!...Have you built anything with it?
    Bob C.
  8. #8
    Sep 2005
    North TX
    1,978
    Default Re: What coloration are you looking for?
    Coloration? Nah.... Just something that will drive a horn up to a couple kHz.
  9. #9
  10. #10
    Sep 2005
    North TX
    1,978
    Default Re: Poor man's PHL
    > it?
    > Bob C.
    Not Jeff, but yes. I bought a dozen to load my upper mids in the Sonic Armageddon system, and d@mn those things sound good. They'll mate pretty well with a ribbon for a high efficiency system.
    See, I'm not the only one thinking 'loud'.
  11. #11
    Sep 2005
    Pennsylvania
    602
    Warren:That's exactly what I had in mind,pairing it up with a ribbon tweeter....Have any pics of the "Sonic Armageddon"
    Thanks Bob C.
  12. #12
    Oct 2005
    16,584
    Blog Entries
    1
    Default PE doesn't offer those. *NM*
  13. #13
    > piece?
    > appreciated.
    If you seek the best in the $120 category,
    why limit yourself to one vendor?
  14. #14
    Sep 2005
    North TX
    1,978
    > tweeter....
    If only the R2's could handle the kind of pounding I subject a system to, I'd have built that already. Experiments at lower volumes (i.e. tube amp levels) were quite positive.
    > Armageddon"
    No good ones - the latest was all unfinished plywood cabs in very poor light. I'm about 2 weeks out from having the paint job complete. Some time after Hotter than Hell I'll set it up for a (cringe) sound check (call the cops now) and photo op. Then I'll need to set up a site to post them....
  15. #15
    Sep 2005
    Pennsylvania
    602
    > positive.
    I will be on the lookout when you post again...I think I might pull the trigger on those drivers real soon...
    Regards Bob C.
  16. #16
    Default Re: Does it compare to the PHL?
    I've used a couple of the PHL's, including the #000 series, 2411 and the 1120.....does the B&C compare sonically with any of these? BTW, the 1120 works VERY well with the AC G2 ribbon. If our questioner was willing to stray from PE as the source, the 1120 is a slam dunk no brainer IMHO.
    Dick
  17. #17
    I'll place my bet.
    PHL 8" wins, albiet at 2.5x the cost of the B&C.
    If someone is willing to dish out a few bills
    for a good ribbon tweeter or compression driver/horn, then go with the PHL product.
  18. #18
    Sep 2005
    Slippery Rock University
    3,286
    Default 1 mm, what am I going...
    to do with that? I know PE offers a mid with 100+ db sensitivity, but with .6mm of Xmax, what would you do with that? If it where going to be used in a Hi-Fi project, would you need a 4-way or just a gradually sloping 3-way to make up for lack of extension, I know it can put out, but 1mm? I guess I' out of my game here, care to edumacate me a bit?
    NK
  19. #19
    The 1120 is a 6.5", which 8" are you referring too? I mean none of them go low low, not even the 18". Can you describe the sound as best as possible? I know it was to be my last post, but his grabbed my attention because I have the bills saved up for some PHL 1120s. Dump us with all the information you have please.
    Paul
  20. #20
    Sep 2005
    6,251
    Default OK.....so these are some zaph reviews for Dayton'
    that is true.....
    Dayton RS150S-8
    Cost: $29
    Usability:
    Build Quality:
    Consistency:
    Value: Comments: The Dayton RS line has been a long time price/performance leader from Parts Express. The harmonic distortion level is not seen in any other driver at this price point. The response curve is a little bit ragged, and the breakup node has 2 peaks, but for the most part it is controllable with a few extra crossover components. The isn't a Scan Speak or Seas Excel level performance, but at this price anyone can be happy with this choice of driver. Bonus points for looking like a stealth fighter. Admit it, looks are important.
    Dayton RS125
    Cost: $22
    Usability:
    Build Quality:
    Consistency:
    Value: Comments: Excellent performing small woofer, though it's lower efficiency will somewhat limit it's use as a midrange driver. This is effectively a 4" midwoofer with a rather large flange. Typical excellent Dayton RS build quality and consistency. Recommended highest crossover point is 2.5 kHz LR4. I don't recommend LR2 usage with this driver. This driver is visually beautiful. Excellent bass performance for this size driver.
    Best Value: Dayton DA175-8 - This is a metal cone driver that, for $19, performs nearly as well as the Seas L18 at lower output levels. At higher levels, a little compression and non-linear BL will become evident due to frame and motor design, but at that price, you can just buy two. It's interesting that the MCM 55-1860 obviously uses the same cone, dust cap and surround, but a change in spiders and a vented motor appear to make a difference in distortion and response. 2nd place for value is the Dayton RS180. Obviously, Parts Express is big on value.
