Results 1 to 6 of 6
    Default 6 1/2 " versus 8"
    A quick & simple ( I hope ? ) one :
    I am building a sub. The box is soon ready. Measured the inside , and realised that the DAYTON 8" Quattro that I was planning of using might not fit ... or is really close of fitting.Maybe simply will not go.
    Should I try it anyway ? For better results.
    OR should I revise my plans , and go for 6 1/2 " instead ? Maybe 2 Pyramid 6 1/2" ??? As they are really cheap ...
    Have to make a decision , as I am filling already the order form to PARTS EXPRESS !!!!
    What will I loose , or gain , by going which ever way ???
    Any tips & ideas , greatly appreciated !!
    e k i
    Default Re: Need to know...
    1 - What is the box volume?
    2 - Ported or sealed
    3 - Objective/Music Listened to, etc.
    4 - Budget
    I really like the tangband 6.5" subwoofer, and their 8" might fit your box as well
    Default Re: 6 1/2 " versus 8"
    Like speaker guy said give us that info. There are many more musical subs or woofers that can provide cleaner sound than that one.
    Paul
    So sorry guys , I (stupidly) though the answer would be so obvious.... it seems it is not !
    1 . The box is about 20 liters ( ? ) . Can make it smaller (inside) by putting sealed baffles inside.I have about 4" for depth.
    2 . Sealed.Made out of MDF.Strong and solid , all seams caulked & glued & screwed together.
    3 . Objective ... just to improve the existing system.I already have a sort of OK set-up. From the factory. Heard a similar car , with only one added amp & similar sub box that I am now building & only 1 sub. Was VERY impressed with the sound.That was PRO made , cost +1000$ ,ouch too much for me ! That is why DIY !!!
    4. Budget , extremely tight !! Spent a lot of money for this car already.... I have one Sub Amp lying around.Intend to use that. Building the box ( a custom one , fits superbly , not visible at all etc etc ) , hoping to squeeze DAYTON 8" in it. So less than 200 for the whole thingy....Covering it with stock looking tan fabric , to make it stealthy....
    Did this help at all???
    I will double check the 8" Dayton size. If it fits , I will try that.
    Wish me luck....
    5,883
    > ever way ???
    > e k i
    In 20 liters sealed, the 8" Quatro will only reach into the 60's (not counting "cabin gain"). You really should port it which will enable it to reach an octave lower (so . . . into the 30's).
    A 2" dia x 6" long port will tune it properly, but will probably chuff. A 3" dia x 15" long port would be better.
    SORRY , forgot to mention that I intend to make it smaller , about half the size. I calculated on a BASS BOX program in my PC , that this element should work nicely in just under 10 liter box. And on Partsexperss site , they recommend a 0.2 cubic feet one. Sealed box. The 0.2 cubic feet recommendation is under 10 liters , right ???
