Results 1 to 12 of 12
    Louavulle, KY
    962
    Default Something for the Big Woofer Set
    Provided Link: http://www.bcspeakers.com/download/p...DF/21NW160.pdf
    I surfed onto the B&C website and found a 21.5" woofer, 6"VC, 15mm Xmax driver they have planned for release this month. No idea how much it'll cost or how it'll sound, but I thought it would be enjoyable to the "big & tall overkill set" lol.
    Cheers / Robert
    Aug 2006
    Tri-Cities, WA
    711
    Default Re: Something for the Big Woofer Set
    > overkill set" lol.
    > Cheers / Robert
    If the specs are accurate, it looks good for a net volume of 4 cu.ft. vented. Tuned to 31hz, the F3 will be about 50hz, but with average room reinforcement, f3 extends to 31hz. With 1000 watts input, the driver will do 127dB output @ 1 meter. Whoa! Xmax of 16mm doesn't get reached until the 1000 watts range, and that only 20hz and lower...where the speaker would be down in output by 18dB. Looks good for a 400-500hz cross. You will definitely need a large horn with high efficiency or a large midrange cone to work with this one.
    4-way with 10" midrange, 5" upper midrange,and 1" tweeter? Anyone?
    John
    16,583
    Default They call it a sub. HAH
    > John
    Anything with an Fs above 25Hz ain't no sub!!!
    North TX
    1,978
    > John
    Pro touring (small, vented, EQ'ed) or fixed install (horn loaded) sub. Wouldn't be my first choice for an overkill home system. B&C makes some nice ~$300 18's that would be better for that application.
    6,251
    Or, as you have many, the Kappa Pro 15LF-2
    BootStrap
    (Originally posted by: BootStrap)
    Jul 2006
    Davis, CA
    1,855
    Default Go
    Provided Link: Charlie's Audio Stuff
    NOT a good subwoofer driver. Too high Fs. Sd is only 1680 cm^3 while an 18" driver has an Sd of around 1100 cm^3. 16mm Xmax isn't bad but still, this is really for PRO sound where frequencies below 40 Hz don't matter.
    For a home sub application, I would go with tried and true drivers from Adire, TC Sounds or even the Dayton Titanic subs. YOu might need two or three but you will definitely get more low frequency output (at 20Hz). Your -18dB @ 20Hz spec means that there is practically no output in the lowest octave.
    If you don't care about 20Hz-40Hz and think that a huge driver is cool, then go for it!
    -Charlie
    ________
    Magic flight launch box
    Kokomo, Indiana
    7,240
    Default Re: They call it a sub. HAH
    > sub!!!
    It's for Pro Sound, Pete. The requirements are quite a bit different than a sub for home use. Of course, I am pretty sure you know this already ;- )
    16,583
    Default It's still just a woofer ;-D *NM*
    North TX
    1,978
    > BootStrap
    Not "many" - only two 2x15 3-way cabs with them. My horn loaders use 12's so I have more of those. Need to pick up 4 more 15's while they're on free ship this month. I'll either use those or the DefTech 18's in the 4 way. Either way, it will be a year long project. The 18's are just collecting dust and need to be used in something but the 15's have their advantages.
    Kokomo, Indiana
    7,240
    Default Re: Yes, it is just a woofer
    They call it Sub because they gave it a lot of Xmax for a Pro Sound driver. Ever look at how much most of these high sensitivity drivers give you? I think the home HiFi crowd is even pushing high excursion woofers into the pro world.
    North TX
    1,978
    > into the pro world.
    The technology deveolped for high excursion subs has pushed the direction of pro sound equipment. Big boxes were the norm, but not so much anymore - if the budget is large. Now it's smaller boxes and enough power to light up a small town. This driver will work in a 4 or 5 cubic foot box. The old Aura 1808 would do that - and it was similar in principle. Probably intended to be used in an easily stackable/transportable "wall of woofers" 20 feet square driven by a quarter million watts.
    16,583
    Default Thaint no replacement for displacement . . . *NM*
