AV Wall plates
I am going to mount a HDMI plasma or LCD display above the mantle on my fireplace.
I am framing out the fireplace enclosure with drywall and studs. I want to run my wiring in the wall and terminate in a single or dual gang box. Seems simple although I have never done this before.
Question:
What kind of wall plate/junction box combination should I get?
I assume I will need an HDMI connector?
Also, can I gang together a duplex receptacle for the power cord in the same box? Or should I separate them? I'll run the power from a nearby duplex outlet.
Re: AV Wall plates
I have not worked with HDMI before, but a decent quality cable and box would be pretty well shielded against EMI from power wires. But still, as a general rule you don't want to run signal cables parallel to power cables, so keep them separate where possible, but for a short run it might be ok to have them together in a dual box.
> Question:
No.. no.. no.. no *PIC*
Provided Link: Carlon split box
It is against code (and not really a good idea) to run power cables and low voltage in the same box.
Carlon does manufacture a split box that is enclosed on one side, and an open mud ring on the other. This will look like a double gang box from the finished side of the wall, but in reality, be a single gange box and a single gang mud ring attached together.
As for the HDMI cable, I would recommend using a wall plate with an open hole in it. then you can just run a pre-terminated cable through.
Hope that helps.
dw
Re: No.. no.. no.. no
I did the wall plate with the open hole so that I would have one fewer video connection. It doesn't look that great so good thing it is hidden. Maybe I will check out PartsExpress to see if they have any.
Bill
> the same box.
> through.
> Hope that helps.
> dw
Provided Link: Monoprice hdmi wall plates
> Bill
Bill,
Check out Monoprice. They sell an HDMI wall plate that is very nice and under 10 bucks. Their cables are also great values for the money.
Dennis
Re: No.. no.. no.. no *PIC*
Provided Link: Decora Insert
Here is an open hole plate that will work with a decora cover.
Put this on the open side, a decora AC receptacle on the other side, cover both with a 2-gang decora cover, and viola!
(I just bought a bunch of this stuff from the distributor linked in the image. I am sure PE sells the same, I just dont know the Part #'s.)
Hope that helps!
dw
