Results 1 to 17 of 17
    May 2007
    Richardson, TX
    472
    Default BR1 x-over midification
    I am taking advantage of the current sale and free shipping to assemble my 2nd kit. But this time I want to try assembling it with the x-over that was reccommended before. I understand that i won't be able to used much if none of the kit's included electronic pieces. That is why I waited till they went on sale. Could someone provide the link to the schematic and specs, I seen it posted before. This project will also, since I am such a noob at building, give me a little lesson in going from a schematic to a finished x-over. How will the different x-over improve the sound?
    Jun 2006
    Atlanta, GA, USA, Earth
    1,954
    Default Re: BR1 x-over midification
    Here's the best crossover for the BR-1
    <A HREF="http://murphyblaster.com/content.php?f=pe_br1.html">http://murphyblaster.com/content.php?f=pe_br1.html</A>
    Here's a good tutorial for building a crossover
    <A HREF="http://www.parts-express.com/project...ver/xover.html">http://www.parts-express.com/project...ver/xover.html</A>
    and another one:
    <A HREF="http://www.speakerbuilder.net/web_fi...xo/xoconst.htm">http://www.speakerbuilder.net/web_fi...xo/xoconst.htm</A>
    and the best one:
    <A HREF="http://www.geocities.com/cc00541/nodal_analysis.html">http://www.geocities.com/cc00541/nodal_analysis.html</A>
    HTH
    -Don
    May 2007
    Richardson, TX
    472
    > crossover
    > and another one:
    > and the best one:
    > HTH
    > -Don
    Thanks Don, that will help a lot. Will I be able to use the included circuit board or will it require making it from scratch, mounting all the pieces on a piece of wood, or something?
    Jun 2006
    1,954
    Default Re: crossover construction
    > or something?
    I don't know that crossover board.
    I'm pretty sure you will need to build your own.
    Use a piece of perforated hardboard - if you can find 1/8 inch it will be easiest, otherwise 1/4 inch is fine.
    Use tutorial #3 "nodal analysis", and layout your components (over a couple of beers.....). Where the components connect to each other, push them through the nearest hole, twist them and solder, then bend them leads flush with the board. You will need to tie-wrap the inductors to the board, and you can tie-wrap caps and resistors also, or just hot-glue them to the board. Mark inputs and outputs with "plus" and "minus", and tie-wrap a foot or so of wire to connect to your drivers and input jacks. You will want to test your crossovers for a few days prior to completion, so use extra wire so you can do this. (Mistakes can happen...)
    Mount your crossover in the cab with short screws or velcro.
    You might like to just modify one speaker to start, and do a comparison of the new to the old.
    -Don
    Good advice. And yes, a new board will be needed. Also make sure you notice that the main discussion on my page is for the unshielded version. I have a mod for the shielded at the bottom of the page.
    May 2007
    Richardson, TX
    472
    Thanks Dennis,
    I ordered the standard version. The thing is, I will be comparing it to the shielded version with the kit crossover. Will that be a "too apples-and-organges" comparison, or is it the shielded and non-shielded close enough for a reliable comparison? And what will I be listening for?
    16,599
    Default Avoid HOT GLUE \:v(
    > own.
    > happen...)
    > screws or velcro.
    > old.
    > -Don
    If you even intend on transporting your speakers, road vibrations can cause hot glue bonds to quit. Much better is caulk or epoxy.
    Otherwise, all great suggestions.
    My experience with hot glue has left me wanting . . . \:v(
    Jan 2006
    Sterling, CT
    3,449
    Default Re: Avoid HOT GLUE \:v(
    Use of hot glue in conjunction with zipties is a better plan. No problems.
    Jun 2006
    1,954
    > epoxy.
    > wanting . . . \:v(
    I agree. A couple of times I used hot glue and it failed pretty easily. Silicon caulk holds great but it's toxic. Paint and MDF dust are bad enough.
    Next project, perfboard, zip ties, and hot glue.
    While I've got you guys here, what do you think about terminal strips or euro-style terminals for crossovers? Seems like they can make the layout very neat, but not a lot of folks use them.
    -Don
    I think the stock shielded crossover works a little better than the unshielded. But you should still be able to hear some improvement in the upper midrange, lower treble. The modified should sound fuller--have more presence--in that area. It should be patricularly evident on brass and program material with lots of instruments.
    Hilliard, Ohio
    2,847
    I've always used clear, silicone sealant to mount my crossover components. It has a vinegar-type odor that completely evaporates in a day, and I've never had a part come loose during transit. I used the Euro-style terminal power strips for inputs and outputs.
    Paul K.
    > glue.
    > of folks use them.
    > -Don
    Default Not that toxic...
    > glue.
    I've noticed the "easy breakage" capability of hot melt glue joints. Helps a little to de-fingergrease the surfaces with alcohol, but especially on those slick plastic cap wrappers, some surfaces just don;t make for a strong joint. I also worry about heat damage to soft polyproplyne caps with that 3-400F glue... but must be not a big problem.
    I've been liking perfboard and tie wraps for the organization it adds, and for temporary layout. When done, glue up! Though, epoxy would be the best for a truly final, long term joint.
    On the silicone glue, the smell really is vinegar, since the curing agent is Acetic acid. Not really toxic, but some worry about corrosion. Let it dry out a few days before putting the drivers in and it's gone. There is a non-smelling, no AA based type, less corrosive for applying to sensitive things, don't know what's in that.
    Jun 2006
    1,954
    Default Re: Euro style term blocks?
    > outputs.
    > Paul K.
    Do you just use regular stranded copper for interconnects, or do you prepare the ends in any way for the Euro style terminal blocks? Looks like it's not gas tight, and I worry about long term stability.
    Looks very clean, though.
    -don
    Hilliard, Ohio
    2,847
    I use solid 18-gage copper wire for interconnecting components when their leads aren't long enough and for connecting components to the Euro-style terminal blocks. I haven't had any come loose or deterioate AFAIK.
    Paul
    > -don
    Default Re: Not that toxic...
    PLEASE...use only the blue colored corrosion-free silicone available at auto parts stores. It's specially formulated to prevent chemical fume reactions with engine system sensors and for making gaskets.
    As a serendipity, it comes in a convenient toothpaste style tube and it's much easier to work with than the clear "vinegar" silicone.
    > big problem.
    > term joint.
    North California
    1,263
    Default Re: Not that toxic... *PIC*
    Why use glue at all? I just strap them down with nylon ties,they dont move and if you want to change something just cut a tie or two.
    Aaron
    Aaron,
    Beautiful design & execution on those networks.
    The attachment methodology was not the intended subject of my post.
    It was meant only as an alternative consideration to the norm for those that wish to secure components using a silcone based adhesive.
    Those much more qulaified than I may wish to debate the most effective method.
    Once again, you display superb HQ work.
    P
    > two.
    > Aaron
