Results 1 to 5 of 5
Thread: HPSA-500
    Apr 2007
    Chicago-ish
    1,034
    Default HPSA-500
    Has anyone had problems with the auto shut off being a bit too sensitive? It seems as though it
    shuts off quite frequently after about 5 minutes or sometimes less of quiet passages in movies or less
    than bassy music, played at lower levels. Is there any way to adjust it at all? or should I just
    increase my "sub-out" level on my receiver and reduce the gain on the amp?
    Thanks for the suggestions.
    -JustinG
    6,991
    Default Re: HPSA-500
    > though it
    > in movies or less
    > I just
    > -JustinG
    Justin I have had that problem on a lot of auto on circuits. The sa240 does it also. Crank the sub-out level up and lower the amp gain. That has worked for me. The worst case is just leave it turned on don't use auto. I don't know if that amp has that option but a lot do . It does not cost a lot of extra electricity If you do that with the sa240 plate amp . I don't know with your amp if that is true, but a lot of auto on circuits are the same design.
    Apr 2007
    Chicago-ish
    1,034
    That is what I thought I was going to have to do. The amp doesn't have an "always on" selection, just off and auto. Thanks for the confirmation.
    6,991
    Justin keep an eye on it once you try that. You might be still under warranty these circuits can break a lot. Phil
    Apr 2007
    Chicago-ish
    1,034
    I might give PE a call tonight then, I think I already have the output at +7.0 dB on my Yammy.
    Thanks for your advice Phil.
    -Justin
