Results 1 to 9 of 9
    3,925
    Default Scrappy Off Axis Response *PIC*
    Below are the measured response plots at 0, 15, and 30 degrees off axis. -Vertical in a 'normal' orientation, or Horizontal as a center channel.
    Not as bad as I'd feared. (Note the expanded vertical scale.) While not ideal by any means, I'd say it would be tolerable as a center channel. The B3N's could be pushed together about a half an inch from the original design, and this would help some as well.
    Slippery Rock University
    3,286
    Default Re: Scrappy Off Axis Response
    So you think putting some felt type material around the baffle would help to smooth things out, especially in the horizontal configuration?
    I know this is a on-the-cheap project, so I'm thinking about some of my favorite "Cash Strapped" tweaks.
    NK
    Lincoln, NE
    929
    > configuration?
    > NK
    Bear in mind that the vertical scale was expanded, so what looks really really ragged, is actually about normal for most speakers. No need for felt IMO.
    > center channel.
    > well.
    I'm not familiar with the design but it seems to be a 2 way MTM. I've always felt that 2.5 way MTM designs were superior with off axis performance horizontally when mounted horizontally as a center channel because the issues with comb filtering are eliminated. In the end you basically just have a TM design on its side so all you are dealing with is the phase alignment between the tweeter and woofer. In either case (2 or 2.5 way) a lower crossover frequency improves the off axis performance.
    Mar 2007
    Springfield, MA
    267
    Default Cabinet design?
    Curt,
    I looked through the threads below, including your x-o posts, but I couldn't find anything on the cabinet size/design. Could you post it or point me to it?
    Thanks!
    Jim S.
    3,925
    Default Scrappy Cabinet design: *PIC*
    Nothing drawn up yet, but this should get you going:
    (Sounds of tape measure going snick, snick, snick.)
    The outside dimensions are 14"h x 6"w x 8"d. The tweeter center is 7" from the top/bottom and laterally offset .75". The woofer centers are each 4" in from the top/bottom and centered on the baffle. The panel thickness was .75" (the solid oak and cherry are optional) and the edges of the baffle had a .5" 45 degree bevel. No internal bracing was used nor IMO, is it required. The enclosure was sealed and lightly stuffed with polyfill.
    Wayne or I will draw up something soon, and I'll post it on my site along with the rest of the info.
    3,925
    I agree with all points. This was not originally intended to be a center channel, so I saw no reason for the additional complexity of the 2.5 way topology. However, since I've got all the data, perhaps I'll model it and see what improvements can be made.
    I will point out that a 2.5 way CC will have non-symmetrical horizontal off axis response.
    Mar 2007
    Springfield, MA
    267
    Default Re: Scrappy Cabinet design:
    > you going:
    > snick.)
    > with polyfill.
    > of the info.
    > C
    Thanks! Looks nice.
    Jim
    Any chance the buyout hivi (299-122) can be used in place of the b3n? My mother-in-law doesn't want a non-black cone :-/
    > you going:
    > snick.)
    > with polyfill.
    > of the info.
    > C
