Results 1 to 9 of 9
    Default Poll: caps and inductors
    What are some of you guys using? Im sure it depends on drivers so maybe you could list that too. I mean whether its paper, metal,fiber, etc.
    Thanks for the input.
    Jan 2006
    Sterling, CT
    3,440
    Default Re: Poll: caps and inductors
    For speakers i use Dayton Poly caps and bennic electrolytics. Madisound aircores or the "Sledgehammer" iron core inductors. Spend the money on the enclosure and the drivers, not boutique crossover parts.
    Provided Link: SOLEN
    > metal,fiber, etc.
    I've been using SOLEN stuff, both caps and inductors for a long time. I also like AEROVOX capacitors. And I try to stick to using only DALE or OHMITE resistors.
    And I never, ever use electrolytic capacitors for crossovers.
    6,991
    solen ,dayton, sometimes a small mundorf silver oil cap with a larger solen or dayton. Like a 7.5uf solen plus a .68 uf mundorf to replace a 8uf. think drivers first caps second. sledge hammer inductors. some hi end inductors {goertz 16 awg foil} with hi end tweeters. Dale resistors at newark.com lots of 50watt values good for high power subs, woofers, etc.
    > metal,fiber, etc.
    Any issues with Janzten??? caps and foil ind
    6,991
    I heard positive about them just never bought them.
    17,561
    > metal,fiber, etc.
    A standard poly/mylar is decent enough. Usually, it depends on the cost of the drivers to make me swing a higher-cost xover. The topology also matters, as SXO's like less series resistance. In that case I used ferrite-cores or the C-coils. I prefer the Jantzen to the Solen caps, but neither are bad. Some say Hovlands are more for metal-drivers, and some others are non-material discriminant. If you go with Dayton, Bennic, ASC, Solen, GE, Jantzen, or even WIMA or Carli, you shouldn't be disappointed. As far as coils, I like Meniscus' prices, and fit where applicable for the lowest cost. Mad's standard coils aren't badly priced either.
    17,561
    Default Re: Poll: caps and inductors *PIC*
    > bought them.
    I like the foil inductors and have used them once. A little more difficult to solder up, but values are solid, and they sound good. The wooden-hub is strange to me, as plastic would still work. In my pair they were not glued in, and slide fairly easily. I wouldn't remove them if I were you! =-)
    May 2006
    Detroit
    735
    > Later,
    > Wolf
    If buying a cap for a specific app(and I do not have the needd values), I usually buy dayton or bennic polys, sometimes Jantzen. If it is a throw-together sort of project I build the values with parts on hand, mostly GE, poly or mylar surplus, and Bennic BP's for shunt values if I do not have the parts or space for poly. Many of my xover's are external, abd it is not uncommon to have 7-8 caps to make up one value. I measure all my caps as well.
    Inductors for HP are usually 19 or 20awg air coils, for larger values I like Jantzen P core inductors.
    Dayton non inductive or Eagle reistors in thought out designs. I prefer these because the leads are better and less likely to break if/when reused.
    Driver cost is a factor in my parts choosing, though with some Neo tweeters, or the HiVi K1, it is easy to surpass the drivers cost. In a series XO I use better, very closely matched parts.
    I think wolf's XO box is a good depiction of what parts to use and where.
    Hope this helps
