Results 1 to 12 of 12
    Default outdoor speaker project
    I would like to build some out door speakers, but I do not know what kind of drivers to use in a project like this. I want to use eight inch wolfers and a nice tweeters. Any sugestions?
    Jan 2007
    Dubuque, IA
    387
    Default Re: outdoor speaker project
    Well, the basics would be cones of alum., poly or some other material unaffected by the elements. Sealed design to keep out the elements/critters, And a box material or finish that can withstand the elements. Other than that it's your choice.
    I am doing the totally tubulars for out around our pool deck...look in the project showcase.
    DP
    Sep 2006
    Her and there
    1,976
    Default moser mt, have the link pete? *NM*
    16,669
    Default Mark K's Dayton Reference RS225/RS28A *PIC*
    Provided Link: 8" 2-way
    Two very nice components make up this two way.
    You couldn't go wrong.
    16,669
    Default The Moser MT uses 7" woofers *PIC*
    Provided Link: Moser XO
    He was looking for an 8" woofer project.
    But, just in case . . .
    Nov 2007
    Shawinigan-sud, Province of Quebec, Canada
    290
    > elements/critters
    Starting in 2002, I worked as a sound engineer for 3 consecutive summers on an outdoor show, 45 shows per season. We had a Servodrive Bass Tech 7 subwoofer underneath the audience seating area for LFE. As the second season went by, I kept experiencing decreasing low-end performance from the system to a point it became ridiculously weak. Some time before the third season began, we decided to open the Servodrive to inspect the drivers, a pair of 15 inches paper cones in a faily elaborate folded horn.
    What we found was a full blown rodent nest made from any stuff the bastard could find elsewhere on the site. The drivers had a punctured outer suspension from where the mice got into the rear chamber, which was packed full of wool-like material.
    No wonder the big box wasn't producing the sound it should have!
    The drivers were replaced and a heavy duty grill was installed on the enclosure's mouth opening!
    BTW, if you don't know about those subs, they are simply amazing and even more amazing is their low popularity. 4 units will produce 142 dB at rated power input, at 28 Hz!
    <A HREF="http://www.servodrive.com/basstech7.html">http://www.servodrive.com/basstech7.html</A>
    Default Re: Mark K's Dayton Reference RS225/RS28A
    > way.
    Ha! I've thought about this. It's not a bad idea at all. The design has full bafflestep which is perfect outdoors, and the drivers, well, they're not really outdoor drivers. But, you could make a faceplate cover when not in use and, if they deteriorate, well, it's not like you left a pair of revelators out in the rain!!!
    Something cheap I did in my back yard was to use the 5 x 7 buyouts sealed in a .6 cu ft 12 inch x16 inch pvc schedule 40 pipe. I driver faces down and the last 7 inches of the tube are open in the front with the cut out piece of the pipe at a 45 degree angle reflecting the sound forward. I use a sub on the patio also made out of the 12 inch pipe with a 10 dvc facing down. They survived 70 mph winds and 2 inches of rain last week. Works for me and sounds good. I had $40 in speakers and parts, the pipe was free, given to me at a local constructon site and I spray painted them dark green to match the plants. The wife loves them so I guess they are ok. Marc
    Default Re: outdoor speaker project *PIC*
    Here is a pic of my outdoor speakers
    > are ok. Marc
    Here is a pic of what I used
    This is a staight on shot of the speakers I glued the mdf tops on with construction adhesive and screws.
