Results 1 to 20 of 20
    Apr 2007
    Chicago-ish
    1,034
    Default Suggestions for a DIY amp
    I'm looking at (along side my NRFD project) making a pair of smallish bookshelf speakers and an amp to run them for my girlfriend this summer. Half the reason is so when I go visit her I don't have to listen to movies on computer speakers. Any suggestions on a pretty easy amp to put together. I can do basic soldering and the like not *great* at it though. I'm good with electrical schematics though. I would have liked to do a small amp/pre amp setup for her (something like a DH101 and DH120) but I think that might be out of the budget for now.
    TIA
    -Justin
    Sep 2006
    Her and there
    1,976
    Default Pyramid PB440
    Pick up one of the pyramid PB440 car amps, I've used it a few times and it sounds nice (tone controls and gain on the amp too). Get a ~5 amp power supply, either one of the pyramid ones from PE, a mini-atx computer power supply, or a 4A switched-mode type used to power hard drives, etc. (I've even run it off a 1A wall wart with success, but you need at least 3A for full headroom). They'll all be around $25. Then some sort of cable to plug in your source. I use a 9 foot dayton RCA to 3.5mm "Y" cable for my ipod. The amp can be pretty easily removed from the blue casing and mounted in a nicer box, just build it around the heat sink and drill holes for the tone controls.
    So all together around $60 and you can power it off a stack of batteries of you want to. I've used it many times and it has some serious volume capability, much better than the t-amp at any rate for about the same price.
    Apr 2007
    Chicago-ish
    1,034
    Default Re: Pyramid PB440
    That has some promise to it. I do have an extra "Power Linear" or some random brand car amp (2x150 watts supposedly) laying around. Good suggestion.
    Jan 2006
    Sterling, CT
    3,452
    Default Re: Suggestions for a DIY amp
    The LM3886 based chipamps are probably the simplest way to get 40-60w perchannel of power. You can use the boards from <A HREF="http://www.chipamp.com">www.chipamp.com</A> for the separate channels, but you don't need the power supply board. Using a regular bridge rectifier, toroidal transformer from PE, and filter caps is fine.
    The only other stuff you'll need is I/O jacks, power switch, volume control, case, and heatsinks - which can be thick aluminum plate or conventional heatsinks.
    If your only input is the computer you could just make it a straight power amp with no volume control, and control the volume in the computer.
    Being conservative you should beable to do it all under 100$. If you have questions, just ask.
    6,991
    Default Re: Pyramid PB440 battery link
    Provided Link: yuasa 12 volt sla battery
    I have some good batteries if you need them. 12 volt 5ah . i have two of these . dirt cheap price. 35 including shipping. see link
    Apr 2007
    Chicago-ish
    1,034
    > fine.
    > the computer.
    > just ask.
    Thanks AJ I had seen some of their stuff and never really heard anything about it. Not quite sure if I will be needing multiple inputs or not yet. When the time gets closer I'll know more this was just to get an idea of what is out there.
    6,991
    > fine.
    > the computer.
    > just ask.
    I have 3 chip amps built if you are interested phil
    > TIA
    > -Justin
    I have been wondering about tjis one for the same application :
    <A HREF="http://www.hobbytron.com/vk4004.html">http://www.hobbytron.com/vk4004.html</A>
    These look like nice kits , but I can't figure out which one would be best for small speakers !
    <A HREF="http://ampslab.com/products.htm">http://ampslab.com/products.htm</A>
    David V. Webber
    Apr 2007
    Chicago-ish
    1,034
    "I have been wondering about tjis one for the same application :"
    Why are you building my girlfriend a pair of speakers?! Yeah amps have always intrigued me. Once I build something I'll let ya know.
    > same application :
    > <A HREF="http://www.hobbytron.com/vk4004.html">http://www.hobbytron.com/vk4004.html</A> These
    > <A HREF="http://ampslab.com/products.htm">http://ampslab.com/products.htm</A> David V.
    > Webber
    Well , not EXACTLY the same application ;
    ( but I'll help if needed ! )
    No , for Christmas we got a new HP Pavillion
    a6320n , which will play DVDs ; and a new " Wide -
    Screen " SAMSUNG 206BW Monitor . The present
    computer speakers sound ( to me anyway , ) just like a telephone ! So , that is why I'm researching solutions !! David
    6,991
    > " Wide -
    > present
    some nice omptimus 7 speakers on ebay would work.
    6,991
    > " Wide -
    > present
    I have a pair of audax vp130g2 coaxial speakers from madisound. they would make good pc speakers
    > same application :
    > Webber
    Also , this little guy is real cute ! BUT , it is " SMT " ; " Surface Mount Technology " . All the components are REAL TINY and soldered onto the TOP of the board . No wires sticking down through holes to be soldered on the back - side !
    I can do it , but I really would prefer not to !
    You need a NEEDLE POINT iron , and a magnifier !
    If anyone should attempt one of these , please post how it went ! Ha Ha . DVW
    > to !
    > magnifier !
    <A HREF="http://www.ramseyelectronics.com/cgi...ction&key=UAM4">http://www.ramseyelectronics.com/cgi...ction&key=UAM4</A>
    Default Now for something different
    > TIA
    > -Justin
    <A HREF="http://www.tubeaudio.com/page23.html">http://www.tubeaudio.com/page23.html</A>
    Just a thought...
    > interested phil
    Would one of your ( 3886 ? ) Chip Amps power one of these :
    <A HREF="http://www.partsexpress.com/projects...ct=HiviJuniors">http://www.partsexpress.com/projects...ct=HiviJuniors</A>
    TIA DVW
    6,991
    > one of these :
    > TIA DVW
    yes they have about 35 watts for 8ohm and 60 watts for 4ohm. I purchased a few from tim rawson a diy amp builder on audiogon. They range in price from 140 to 240. mostly due to the case difference or volume control of not. I am getting rid of them because a purchased a 5 channel one. for my tweeters. phil
    > phil
    Would just one amp be stereo , or do you need a pair ? Are there any photos of similar ones on
    Audiogon or any of the chip - amp sites ? DVW
    6,991
    > similar ones on
    > DVW
    I have one with 1 input 2 rca's 2 sets of binding posts. stereo about 8 by 5 by 5. I can send pictures on wed email me at <A HREF="mailtohiliparcario@yahoo.com">philiparcario@yahoo.com</A> it has a volume pot an on off switch and an iec jack color is black.
    6,991
    Default Re: Pic of a small in size gainclone
    Provided Link: gainclone pic
    This is one of the diy gainclones I have It is the smallest one i have.
