Results 1 to 4 of 4
    Jul 2007
    southern Ontario, Canada
    1,856
    Default 2'' PORT? PIC PIC *PIC*
    I'm trying to find a 2'' port similar to the one pictured here.
    <A HREF="http://www.partsexpress.com/imageslarge/302-017ii.jpg">http://www.partsexpress.com/imageslarge/302-017ii.jpg</A>
    Default Re: 2'' PORT? PIC PIC *PIC*
    Provided Link: 2&quot; Port Link
    Would this one work?
    452
    Provided Link: http://www.partsexpress.com/pe/showd...number=260-386
    once flush mounted, this one many look similar.
    Default Make your own
    > one pictured here.
    Use a piece of 2" PVC pipe or conduit. Cut a 1-1/2" hole in the back of your cabinet, then cut a rabbet just wide enough to accept the PVC pipe section and 1/4" deep. Cement the pipe in place with all-purpose pipe cement (not clear PVC cement; you want the milky stuff that's also good for CPVC and ABS.) After the cement has set overnight, use a flush-trim bit in your router to trim the hole in the cabinet back flush with the inside of the pipe. Then round over the rim of the hole with a roundover bit. Depending on the thickness of the back, you can make the roundover any radius between 1/8 and 1/2 inch. Don't forget to cut the pipe a bit longer to allow for the radius on the port; it affects the acoustic length of the port. For a 1/4" roundover, I typically add 1/8" to the length.
    HTH,
    Bill
