Playing music through laptop
Does anyone know why I would get an, what I am going to call an oscillating sound, when I play Sirius radio from there web site through a wireless router. This doesn't happen while playing music through Media Player.
Thanks Dave
Does it happen when...
you are hard wired to the router?
Re: Does it happen when...
I am at work so I wont be able to check that till I get home. If that is the problem is there a cure for it or is that the way it is?
Thanks Dave
Re: Playing music through laptop
> Player.
> Thanks Dave
Sirius _may_ have a problem with your ISP, local network connection, or your wireless router.
To check this, try playing other audio or video streams from the Internet such as on <A HREF="http://www.cnn.com">www.cnn.com</A> ot <A HREF="http://www.nbc.com">www.nbc.com</A>. If those are ok, then it is a Sirius problem.
If not, then I would suspect a wireless problem.
Lots of variables in that. Hard to say.
Wlan troubleshooting - make sure no one else is using your wireless bandwidth, make sure you are using a channel that is strong. You can check for wireless problems easily by using a lan cable from your laptop to the router.
HTH,
-don
Seems to be a Siruis issue...
> router.
> <A HREF="http://www.cnn.com">www.cnn.com</A> ot <A HREF="http://www.nbc.com">www.nbc.com</A> . If those are
> problem.
> router.
> HTH,
> -don
I checked out the sites you posted and they seem to be fine.
The problem I am having does it on my router and the one I am using at work.
If it is a bandwidth problem due to being on a wireless conection make sure the router is closed. Haveing an open router can leave you other computers leaching your bandwidth. Don also had some excellent recommendations below.
HTH
-Brian
> is?
> Thanks Dave
Re: Seems to be a Siruis issue...
> seem to be fine.
Well, the fact that you have the problem at work and at home means we can rule out any local ISP problems.
So, connect a lan cable from your laptop to the router(s) and see if the problem is still there.
If not, you have a wireless specific problem.
You might want to check your wireless router's tech support for tips.
-Don
> local ISP problems.
> still there.
> problem.
> -Don
I will do that this weekend. I found a volume control on sirius web site and turned it all the way up and it seems to be better. I will try the cable this weekend to see what it does.
Thanks Dave
