Results 1 to 9 of 9
    Default Phenolic back wood veneer info
    well, after talking to a few people about box building, i always recommend a phenolic backed wood venner. It seams most people dont know abotu this, so i though i would post up what it is.
    1st, phenocil resin in a hard resin, and used in makingplastic laminates. basically plastic laminate is layers ofcraft paper, soaked in penlic resin, and then the top color sheet is attached.
    a phenolic backed venner just uses the same backing as a laminate instead of paper or another layer of cross grained veneer.
    Why is this better? Well 1st, its stiffer and thicker, so it contours more smoothly to the surface, unlike a paper back that will show the slightest flaw.
    Also due to the phenolic, it wont easily dent. It is just as resistant to dents as a plastic laminate
    Also it finishes easier. The phenolic is a true barrier between the glue and the venner, so you dont have to worry about the finish interescting with any solvents in the glue, ect
    Now, the only negatives are it leaves a black line on the corners just like a plastic lamiate would. I dont mind this, and with carfull box construction you could minimise the amout shown.
    Cost is also slightly higher as wll, but i fel its well worth it
    here are some pics
    here is it applied to a radius desk
    pics of corner
    full sheet pic
    pic pf phenolic backing
    hope this opens up another option of veneers to everyone
    Check out my website: www.freewebs.com/uber-stealth.
    Now offering cnc cut baffles and other speaker cabinet parts
    Sep 2008
    NE, IN
    3,366
    Default Re: Phenolic back wood veneer info
    --Where do you source your veneer?
    --What type of adhesive do you use?
    Majestic Saw Mill River Valley
    1,573
    Quote Originally Posted by nikbrewer View Post
    Nik,
    great info and option to have in our back pockets. I assume that this veneer still does not resolve the problem of veneering roundovers smaller than 3/4"?
    - John
    i buy it locally, but remeber, i work at a commercial cabinet shop. just call the local plywood suppliers and tell them you whan phenplic backed veneer. come sin 4' x 8' sheets like p.lam. We sometimes will used a water based venner glue, but most og the time we apply it just like a plastic laminate useing a spray contact adheasive
    Tucson
    48
    Whoa, "spray contact cement"? What a great idea! What name would I look for? That would sure remove one really nasty part of veneering. Thanks!
    you can use the 3m super 88, but call around to local cabinet shops or suppliers and stry to find sta'put or star stuk.
    Also, this will not o tight radius at all. It acts just like a plastic laminate.
    However, if you laminated a box with this, the rabetted out all the corners, lets say 1/2" x 1/2". you could thn glu in some hardwood, put a round over on it, and you would have round corners AND no black lines
    Tucson
    48
    Thanks, Nick. I want to make sure I've got this correct: can I use the spray adhesive on paper backed veneer too?
    i have done it, but would be leary on what finish you use. the solvents in the glue sometime soak though the paper and show up in spot in the inish, or sometimes the finish soak throu and affects the glue. i like water based contact glues for wood and paper back veneer
    I work for a Phenolic Manufacturer. We've been producing Phenolic products for over 20 years and are very experienced with this material. I can provide materials for anyone who is interested in building a phenolic speaker box. If you want more information you can send me a message. Also check out our website www.specritedesigns.com
