Results 1 to 12 of 12
    Jul 2007
    southern Ontario, Canada
    1,856
    Default Where to put the port?
    This box is 2 cu. ft. with a port size of 3'' W x 4'' L. Where should I put the port?
    Default Re: Where to put the port?
    do you want front or rear firing? maybe side? shake it up a little
    5,699
    If the cab's going to have feet I'd put it on the bottom.
    Jul 2007
    1,856
    I thought of putting it on the bottom and that is my prefered but I'm concerned about the air from the woofer blowing across the port.
    Quote Originally Posted by gowa View Post
    if you factored in an elbow and faced it towards the back you could do it. probly not ideal though
    Nov 2007
    Des Moines
    680
    If the enclosure is continuous from the woofs to up behind the tweet, I would mount it rear firing behind the tweeter.
    Port implementations (in my opinion) are:
    50% good port (flared both ends best)
    25% cosmetics
    25% space limitations
    If the port is well designed, you could have it coming out of just about any face of the enclosure you would like. I've done both front and rear firing, and have listened to many with down-firing ports (like Jim and Curt's Statement series). In my most recent design, the port exited on a 45-deg face out the back/side quarter. All work well. I've not seen one out the top - go ahead, be the first...
    Sep 2008
    Sunnyvale, CA
    1,724
    Quote Originally Posted by tpremo55 View Post
    Here you go, out the top.
    http://techtalk.parts-express.com/sh...d.php?t=208207
    Need to keep it covered when not in use so stuff does not collect inside the cabinet.
    Louis
    Nov 2007
    Des Moines
    680
    Quote Originally Posted by Ludo View Post
    Louis
    And there ya have it. Little opportunity to be original 'round these parts...
    Sep 2008
    Sunnyvale, CA
    1,724
    Another option is to bring the port out the bottom into a shallow, lets say 4" chamber which has lots of 1/2" x 3" vertical slits along the two sides and back; then adjust the tuning experimentally to compensate.
    I haven't tried it yet, but plan to on a tower pretty soon.
    Louis
    5,877
    Louis
    Or, on these, I used a "cage" of hardware screen (1/4" holes) around the bottom, so if, say, a "Hotwheels" accidentally falls in there, I can just tip it over to get it out.
    5,699
    One reason for bottom mounting is that out of bandwidth noise is filtered.
    DePere, WI
    4,250
    Front-mounted slot port?
