Results 1 to 7 of 7
    Default Hot resistor questions
    When a resistor is driven near its power limit, and it heats up, does its resistance rise with temperature? If so, by approximately what percentage of its nominal value?
    16,604
    Default Re: Hot resistor questions
    Quote Originally Posted by brianp View Post
    Thermal coefficients vary with resistor type. 100ppm/degC would be a reasonable guess. In other words, the value won't change appreciably.
    Schumakubin Plans
    The Fraud Continues || Hoax
    Tennessee
    490
    I agree . . until it burns on two! Expect a substantial rise in impedance at that point!
    I suppose a test could be done to measure a wire wound at ambient room temp, then place the thing on a stove burner, turn it on high and see what happens as she heats up.
    Let us know how it turns out!
    Dave H
    16,604
    Quote Originally Posted by Hackomatic View Post
    Once you let the smoke out of the part, it stops working.
    Magic smoke . . . isn't that what Michael Phelps was trying to inhale?
    Schumakubin Plans
    Tennessee
    490
    Um . . I think he more than tried!
    Maybe in his quest to become an Olympic star he consumed too many Weedies.
    Dave H
    5,699
    Yes. That's how tweeter protection lamps work, and what causes thermal power compression in drivers. A good rule of thumb is to use a resistor that's rated for at least twice the power that will actually pass through it.
    Aug 2006
    Kingman, Az
    1,448
    As per usual bilf is replying to a question when he should not.
    The first answer (from Pete Schumacher) is absolutely correct.
    Resistors are temperature compensated and relatively stable with temperature.
    There are low temperature coefficient types and low noise types neither of which are ever necessary for a crossover.
    The voice coils in your drivers on the other hand are simply coils of copper or aluminum which will exhibit large swings in resistance with temperature.
    So your systems characteristics will vary considerably but because of voice coil temperature not resistor temperature.
