Results 1 to 17 of 17
    Default Building a cheap computer sub: Dayton SD215-88
    I want to build a cheap computer sub to use with my Madisound RB's. I ordered the Dayton SD215-88 and a Foster plate amp from NHT. WinISD gives me a somewhat flat response curve in a 1.85 ft^3 box with a 1.5x10x15 inch slot port. Anyone have experience with this driver?
    sk, Canada
    261
    5
    Default Re: Building a cheap computer sub: Dayton SD215-88
    I am thinking you might not have applied the stock boost as listed here. Are you intending to modify the response?
    http://home.comcast.net/~jhidley/
    I see, the Foster has a built in bass boost. Which would be easier, compensating for the bass boost in my box design or modifying the plate amp for a flat fr?
    Build it sealed. The +6 db boost at 30hz in 1 cuft will give you a fairly flat response where the F6 is at 40hz or so. Either way be carefull, that amp can easily tear up that driver. 25-30watts is all it needs to reach max excursion. I see no benefit to a ported alignment with a driver with an Fs of 34hz. The amp has the boost and allows for the smaller box and more simple construction.
    Quote Originally Posted by Mayhem13 View Post
    Thanks, it looks like with the built in bass boost sealed is the way to go. This will be a computer sub placed near my feet, 20 watts should be plenty.
    sk, Canada
    261
    5
    +6dB at 35hz isn't that use full in a vented alignment like you started with.
    You may be ok with sealed but vented would allow you to play lower(f3) and with more output around fb at least.
    I suggest at least modeling a vented box with a bit of boost and using the high pass on the low end as a subsonic filter.
    Quote Originally Posted by ocool_15 View Post
    The Fs of the driver is only 34Hz...no real return in trying to go any lower..port length and resonance become a problem.
    OK, I figured out how to add eq in WinISD. Adding eq to that driver in a closed box makes it exceed x-max with only a few watts. In a vented box, the bass boost allows me to use a much smaller enclosure (~1 ft^3), while still being able to handle ~25-30 watts before reaching x-max. Getting a flat curve is pretty tricky with this driver, but I don't expect much for $20. My finished sub will still be cheaper then the SUB-80
    How is this coming along? I am wanting to do the exact same thing as you. I also thought about using the Tang 5 1/4" driver. Which Dayton plate amp do you think would work the best, the 25 watt or the 70 watt? Also, what about a passive radiator instead of a port? Is there any benefits? Please post some pictures when you get it done and let us know what you think.
    Sioux Falls
    12,889
    I used the 5.25" Neo Tang Band and like the results in a 0.38 cubic foot enclosure, tuned to (I think) somewhere in the low 40's. It gives me a theoretical F3 of about 36 Hz.
    The 70 Watt might be a stretch for the little guy - but who knows? Worth a try.
    The major advantage of a passive radiator over a port is low tuning in a small enclosure. I first built mine with a 1.5" round port but it was awful noisy. I went with a slot port about 1/2" by 7". Much quieter. Putting a 2-2.5" port in there would have required a not inconsiderable length for the little volume. The slot port doubles as a nifty brace as well, allowing a longer path.
    9,199
    Quote Originally Posted by a-dub View Post
    Here's my $50 (OK, $51) sub from last year. I got both the driver and the SA25 plate amp on sale at different times for $19 and $32.
    3/4" box, outside H = 15", W = 11", D = 20-3/8", 1.4 cf gross, 1.32 net.
    3"id x 16-1/2 port, Fb = 27, F3 = 27.
    Quote Originally Posted by okiejaco View Post
    The speaker and amp were delivered last week, but I have been out of town from fri-sun. I have this week off and should have my sub built in the next couple of days. I'll try to remember to take some pictures and keep you updated on how the sub works.
    Nice looking sub My total cost should be about $75 including amp, driver and cabinet materials. How is yours working out?
    9,199
    It definately goes LOW. The 25w amp underpowers it, but it's used to fill out the bottom end in the basement w/ a pr of BR-1 clones, so not real loud, but very nice. Most use the SA70 with this driver. I actually made these TB 3"ers (sealed/stuffed) for computer speakers to go with it.
    OK, finally got around to taking a picture of my new sub. I haven't decided if I'm going to finish it or not, it sits under my desk and I prop my feet on it. I might just cover it with some auto carpet. Total cost for this project was:
    Driver: $23
    Amp: $32
    MDF: $7 for precut 2x4 foot sheet
    Total: under $80 after shipping.
    The outer dimensions of the sub are 11.5W x 13.5H x 16D, it's a bit larger then I would have liked, but for the sound I think it is worth it. The sub it replaced is shown in the photo as well.
    Here's a shot of my computer setup with my Madisound RB speakers. I have a behringer crossover on order as well. The entire setup including the Madisound speakers, sub and crossover totals about $275 (the receiver I'm using was free), and I think it's a pretty killer 2.1 computer setup.
    The Dayton sub crushes the one it replaced. It has useful output down to about 30Hz. My old computer sub bottomed out at 40Hz, and was just a boomy, muddy mess. My first impression is that it is just a tad muddy, but after some listening I think either it is breaking in, or I am just getting used to it. Overall, I am very happy with the performance, it is great for gaming, and far better for music then my old sub. I owned the Dayton SUB80 before I upgraded to a DIY Kappa Perfect 12 for my HT. This sub is smaller then the SUB80, and does not have the port noise issue either. Two thumbs up for a super budget sub solution
    Good looking sub. How do you hook the sub into the hardrive? I noticed that you went with the ported version of the rb. I went sealed and have thought about doing a ported. I am powering mine with an Adcom 535. It is almost too much. Do you think it would be worth it for me to do ported cabinets, since I am going to be running a sub? How big is your vent and did you just cut the notch or did you make a tunnel? Sorry for all the questions but I want to be prepared when I do mine. I may have some more later on. Thanks for posting you pictures and build.
    If you look closely you can see the receiver below my computer. It has a subwoofer output, but it is not adjustable so that is why I ordered a crossover.
    http://www.parts-express.com/pe/show...TOKEN=42018702
    I scored a used one from ebay for $60. The vent is 1x6 inches, and 15 inches long, all cut from MDF. A 3" pvc port would also work, I just decided it would be easier to make from MDF. I kind of wish I had gone with the sealed RB's, the ported ones take up a lot of space as you can see in the picture.
