Results 1 to 11 of 11
    Default Don't let this happen to you
    Last night I assembled the PE BR-1S kit. I put everything together without testing first. That includes hot gluing in the crossover and caulking the woofers. When I hooked them up to my receiver, the left speaker worked but not the right.
    There was nothing to do but disassemble the non-working speaker. In the course of prying out the woofer, I broke one of the speaker terminals which I forgot to screw back down. Removing the crossover was fun. I was able to get it out using a hair dryer and a putty knife. I had to stop in the middle of that because I knocked over my beer with the hair dryer cord.
    So anyway, I take it apart. The solder joints look fine. I test what I can with a continuity tester. Everything was fine. Turns out I wasn't getting any voltage on the right channel of my old receiver. I should have checked that first. D'oh!
    By the way, is there a drop in replacement for the terminal cup for a BR-1S? I'm using an alligator clip for the moment.
    Jim
    Default Re: Don't let this happen to you
    Quote Originally Posted by jliedeka View Post
    I will be damn sure not to let that happen to me
    STOP. (100110) WASTED SPACE. (0100110101100)
    INFORMATIVE INFORMATION. (0)
    Mar 2008
    Malvern, Ohio
    2,980
    Sep 2008
    NE, IN
    3,366
    I've always figured that the best way to learn s by making tons of mistakes. Just don't spill the beer on the speeks.
    Side note: If you build tower speakers, someone will put there beer on them. Don't go all shellac since the alcohol will ruin the finish.
    Jul 2006
    Davis, CA
    1,855
    Crap! If I went through that same experience and then found out it was the receiver, that is when it would be sent flying through the window to the street below!!! Wow, I am not kidding, that would really have sent me through the roof.
    I think that this is why separated are a better approach (versus the all in one receiver), since you can swap out components, add/change/delete components, etc. easily and this makes for a good way to test for problems.
    Also, it is always a good idea to check for loose connections when there is no sound or something funny with the sound (e.g. drououts/distortion). That is now step one in my book as I have found this to solve a few problems for me in the past.
    -Charlie
    Jim
    One of THESE oughta fit:
    http://www.parts-express.com/wizards...TOKEN=57934395
    Long time ago, Rat Shack carried such items. Dunno if they still do. Worth checking, though.
    Feb 2009
    chesterfield michigan
    221
    what a god darn travesty .... beer running afoul due to electrical appliance entanglement.
    i have had those days and sorry to hear about your misfortune with your speaker project. at least you get a new receiver out of it !!
    david golemba
    Chehalis, Wa.
    4,797
    Jim
    I just checked my BR-1 and the overall diameter is 2 15/16" and the cut-out hole is 1 7/8". This one looks to have the same dimensions, but not the same terminals/binding posts as the stock BR-1:
    http://www.parts-express.com/pe/show...number=260-294
    This one has the binding posts like my original BR-1 cup:
    http://www.parts-express.com/pe/show...number=269-376
    That first one has the little spring clips, but the second one is closest to the binding post style stocker. Be aware that part #269-376 says it needs a 2" cut-out, which is a bit bigger than the stock opening. It seems the only terminal cups that have the right cut-out size are those spring clip ones.
    Pioneer TX-9500 II tuner
    Statement Monitors
    Photo site:
    My blogs:
    Thanks for the suggestions.
    The beer was a Spotted Cow. Luckily I only lost about 1/3 of the bottle but that's still too much.
    I think I'm going to get a close-out NAD T-744 to replace the old Yamaha. On paper it's a little underpowered but it should be plenty for a little used bedroom system.
    I thought it was weird that I had a bad channel in the receiver. I used it for over 10 years without a problem. Since I replaced it with a Marantz, it's just been sitting on a shelf in my bedroom waiting for speakers. Guessing I made a mistake on the first soldering job I've done in a long time seemed like the right assumption.
    Jim
    Mar 2009
    CT
    629
    I had a similar experience with an electric clothes dryer. It spun, but no heat. I tore it apart, thinking it was the heater coils or the thermal safety switches (I think there were 3 total).
    The problem turned out to be the circuit breaker in my house. It was 220VAC, but was only putting out 110VAC on one leg and 0VAC on the other. I wasted a lot of time and effort, but learned a lesson!
    DePere, WI
    4,250
    LOL. That told me you were a fellow Wisconsinite before I even glanced up at your profile. ;-)
