Results 1 to 18 of 18
    Default Cheap XO PC Boards
    Does anyone know where i can find some cheap pc boards im thinking of building the Dayton 3 MTM crossovers.
  2. Smile Re: Cheap XO PC Boards
    I have used both of these pc board fabricators:
    http://www.4pcb.com/
    http://www.expresspcb.com/
    They both have free software that you can download. They will make double sided prototype boards for around $50. After desiging the board, the software uploads the design to thier servers and they fabricate the boards from the files. A credit card is required to pay when ordering.
    Dan
    SE Pa
    222
    Default Re: Cheap XO PC Boards
    I have some 4 mm marine plywood leftover from a project. CHEAP!
    If you arrange your components strategically component leads can be directly soldered together through holes drilled in the board. Minimal jumpers are required.
    Unless the XOs are visible, I don't see any reason to make them too pretty
    Hal H
    Oct 2006
    Seattle,WA
    451
    Plywood works, although I tend to use 1/8 inch perforated masonite (peg board) if it's available. You can use hot glue and wire ties for holding things in place, with heavy gauge solid copper wire or tinned stranded wire for "Bus Bars."
    Point-to-point wiring is not only the mark of a Custom/High-End product, but allows for easy upgrades and modifications with minimum downtime. Let's face it, PC Boards are for mass produced products and other than an active crossover, are really of very little utility. PC boards encourage compact grouping of components, which in the case of inductors is not the ideal situation in any case.
    If you are using a two way parallel crossover you might want to use two separate boards, with one for the treble and the other for your mid/bass drivers and mount them some distance apart. Series crossovers are a bit different, but that's probably not what you're planning on using anyway.
    Best Regards,
    TerryO
    17,559
    Quote Originally Posted by AudioFreakca View Post
    Here's an example:
    and the thread with lots of pictures for inspiration:
    http://techtalk.parts-express.com/sh...physical+xover
    Have fun!
    *InDIYana 2013 event*
    If you really want to keep it simple, there's nothing wrong with good old cardboard and hot glue... electrons aren't too picky about aesthetics.
    Form does not follow function
    Chicagoland
    4,033
    Quote Originally Posted by terryo View Post
    +1
    Pegboard + zip ties and you're good to go! Honestly, building a XO is not nearly as difficult as it seems. In fact, it's one of the most enjoyable parts of the build--for me anyway. For understanding how to read a schematic, there's no beating Curt's nodal analysis, and for the actual construction, Wayne's guidelines are great.
    Iowa
    382
    I etch my own. It is fairly easy and cheaper than the online services.
    madisound also sells a couple different generic XO boards including a matrix type that can be adapted for almost any layout.
    Regards,
    Dennis
    manassas, va
    1,110
    Go to THE SHACK! They have a couple different sizes. A few bucks.
    I just found some at radio shack (thanks Kid) http://www.radioshack.com/product/in...ductId=2102862 would these work?
    Sep 2008
    Sunnyvale, CA
    1,724
    That's what I use. The ones with the 0.062# holes are the best - will fit even the larger inductor leads without any drilling. Push all the component leads through the holes, wire up on the backside, solder, add tie wraps to the heavy components, test, and finally hot glue.
    Louis
    Dec 2008
    Long Island
    2,574
    For inside, I use spare pieces of MDF. Drill holes and glue where appropriate.
    http://www.diy-ny.com/
    Oct 2008
    1,070
    Here are some pretty reasonably priced generic XO boards. Pretty good variety of sizes, too.
    An alternative is island pad style PCB. For a small run,
    you could use wood paddle hole drill bits instead
    of the diamond bit mentioned in the link below.
    http://www.cliftonlaboratories.com/P...ad_Prototyping
    Prescott, AZ
    1,648
    Default Brief Hijack
    Why the ceramic cap Wolf?
    Here's an example:
    Have fun!
    in front of a computer
    999
    Default Re: Brief Hijack
    My last crossover used no board at all. I made separate units for the woofers and tweeter. I attached the caps and resistors to the inductor, then velcroed the inductors to the cabinet walls. This required two separate runs from the terminal cups, but the crossovers are easily removed and modified. Obviously this only works for relatively simple crossovers....
    cardboard and a hot glue gun
    17,559
    Quote Originally Posted by maynardg View Post
    What ceramic cap? The little part you are referring to is a polyswitch protection device for the tweeter.
