Results 1 to 11 of 11
    Jan 2008
    Oak Creek, WI
    143
    Default Compensating Recess For Foam Tape
    If one is using foam speaker tape that is 1/2"X1/8" thick then the recess for the speaker flange must be routed 1/8" deeper than the the flange.
    Is that correct?
    Or is there a different approach?...Thanks
    Iowa
    382
    Default Re: Compensating Recess For Foam Tape
    The gasket take will compress as you tighten the driver down. So it will be less than 1/8"
    Regards,
    Dennis
    sk, Canada
    237
    5
    You have to compress it and measure, The nice stuff I use that is low density compresses to ~.51mm if I remember correctly. You basically have to measure whatever product your using.
    Bremerton, WA
    920
    I usually squeeze the foam with calipers (on the blade area with some cross section) to figure out what the thickness will be when compressed.
    5,708
    Quote Originally Posted by jimofoakcreek View Post
    Is that correct?
    The tape compression can be assumed as complete, so no additional recess beyond the actual frame thickness is required. Where recessing frames is concerned keep in mind that anything less than 1/4 wavelength within the driver pass band is essentially acoustically invisible.
    manassas, va
    1,111
    Geez Bill, you had me understanding you until you threw in the 1/4 wavelength thingy! Please explain this to me - the lesser undrstanding.
    5,708
    Quote Originally Posted by the kid View Post
    The primary acoustic reason for recessing is so that the wave won't wrap around the driver frame, reflect off the baffle and then merge again with the original wave far enough out of phase to cause a response bump or dip. If the distance the wave has to travel around the frame to the baffle is less than a quarter wavelength the phase differential usually isn't problematic. It gets even more complicated, for if the radiating plane is more than a wavelength in dimension the wave won't wrap around the frame anyway, its dispersion angle will be too narrow. What it boils down to in practice is that few woofers will benefit from recessing, some mids might, as will most small tweeters. But from a visual standpoint the larger frames of woofers means they're more likely to be recessed.
    manassas, va
    1,111
    Thanks for the reply Bill. I was at least thinking a little something like that for the woofer.
    Question Re: Compensating Recess For Foam Tape
    Is off-setting the tweeter in the baffle an alternative to recessing?
    Chehalis, Wa.
    4,803
    Quote Originally Posted by PunkSweeper View Post
    Short answer: no.
    For jimofoakcreek, most of the foam gasket tape I use (like the stuff PE carries) will compress down to about 1/32". Some of the hardware store stuff might be different according to the density, but I try to find closed-cell foam of a medium-to-firm density. I add 1/32" to the depth of the recess for all my mortises and it's worked very well. Maybe 1/64" could work, but it really depends on the gasket material. Smash some down and see how far it'll compress. If you add 1/8" to your mortise depth, it will be too much.
    Pioneer TX-9500 II tuner
    Statement Monitors
    Photo site:
    My blogs:
    Oct 2008
    1,070
    Quote Originally Posted by johnastockman View Post
    Short answer: no.
    FWIW, the closed-cell foam that John is referring to can be found at Lowes. They carry both types, closed and open-cell, so you'll be able to compare and see the differences. I too prefer the closed-cell. It's just a gut feeling thing, but I think it will last longer before deteriating and perform better than the open-celled.
