Results 1 to 17 of 17
    May 2007
    Athens, Ohio USA
    1,163
    Default Circle cutter guide for jigsaw?
    I need to cut a dozen 5" diameter holes in some braces, and I don't look forward to doing them with a router.
    I've got a Bosch jigsaw that needs to earn its keep, and while I could cut the holes freehand, I thought that I'd try for something better. Bosch makes a combination edge/circle guide for it, but reviews show it to be weak plastic.
    Festool makes a similar guide for their jigsaws (but made of metal instead of plastic), and I wondered if it would fit in the Bosch.
    Here's the Festool guide...
    If anyone here has dimensions of the part the slides into the Festool jigsaw, I'd appreciate it.
    I can always make an extended plate for the bottom of the Bosch if this doesn't pan out, essentially making a simple "Jasper guide" for my jigsaw.
    Bill Schneider
    One word = one milli-picture
    Cedar Rapids, IA
    1,176
    Default Re: Circle cutter guide for jigsaw?
    Hey Bill, I have seen your work and bet you could make something just as nice Maybe start with a piece of 1/4" masonite or plywood as a false base plate and add drilled & tapped hardwood or aluminum blocks on either side of your jigsaw's base that could clamp down a steel or aluminum rod via thumbscrews. Oak tapped to 14-20 can do a pretty good job in a pinch! Drill a hole in the pivot end of the rod and you'd pretty much have it!
    May 2007
    Athens, Ohio USA
    1,163
    There's going to be some DIY in whatever I decide to do. The Bosch jigsaw base already has a pair of slots for a flat metal "rod" (like the Festool jigsaw shown), so I'd probably use that instead of making blocks for a round rod IF IT FITS.
    The Festool attachment is only $25, so if the flat metal "rod" fits the Bosch base too, I'd be mostly there. If not, well... Plan B.
    Your post did remind me that I have a Bosch router guide that does circles, and perhaps I can use that instead. It has round rods, so I'd have to make a jigsaw baseplate to accept them like you suggested. The nice feature on the Bosch router guide is that fine adjustments are screw-thread adjustable like a micrometer.
    Bill Schneider
    Feb 2009
    Courtice, Ont.
    972
    I had a quick look at my Bosch jig and it looks like a 1/8" x 3/8" (or so) bar would fit in there. Obviously measure it and get a bar that fits at the local metal supermarket. For the pivot end just drill a 1/8" hole at the end, I cut old 1/8" drill bits up and use the shaft as a guide pin. The big issue though seems to be how to hold the flat bar securely in the jig saw base. If I get some time tonight I'll look a little more closely at it and pass along any ideas... if I have any.
    Questions:
    #1.) Why don't you want to do this with a router?
    #2.) Would something like this work for you? I have one and they do OK but not a precision tool for sure. Drill press only!
    I just saw they make a beefier version that I think I'll have to pick up for myself.
    May 2007
    Athens, Ohio USA
    1,163
    Yeah, I know there isn't a locking screw on the jigsaw base itself, so I'd have to drill and tap something there. Could be tricky because the only "meat" is on the bottom of the jigsaw base. But I can't have anything sticking down for obvious reasons.
    I don't want to use a router because of depth-of-cut limitations using a spiral upcut bit. I dislike incrementing a cut 1/8" deeper each pass - it slows things down.
    I've also been "banned" from running my router indoors because of the dust. The jigsaw would be much better in that regard because less material is removed.
    I have used circle cutters like your link shows in my drill press, but I didn't like them much. They require a lot of torque, and could possibly damage my nifty aftermarket Jacobs chuck.
    Bill Schneider
    May 2009
    Leduc Alberta Canada
    418
    I inherited an old Craftsman Jigsaw from 1960 with 3 speed selection and it has a 1/4 thick by 3/8 wide channel and what I did was got a piece of steel from my Brother in-law and put the steel in the jigsaw left about 1/2 overhang on one side then scribed two marks right against the base where the steel slide through and then pre-drilled a couple of holes and tapped them so that I could use the screws as stops on either side and with the remaining 14 -16 I drilled a few wholes where I needed them to be and tapped them with a 1/4" screw that was 2 long and then ground the tip so that way I could screw into the piece and not have to worry about it moving. I needed to make 14, 16 and 18 wooden wagon wheels for a project.
    Worked out very nice...
    WayneN
    Apr 2009
    N. Atlanta GA
    498
    Oh just man up and cut them with the router ... it didn't take me long to cut 48 holes.
    http://www.htguide.com/forum/showthread.php4?t=34726
    8,074
    if you figure the distance from cutter to outside you can make a guide and use a patern (top bearing) bit and just follow once and repeat.
    May 2007
    Athens, Ohio USA
    1,163
    Quote Originally Posted by WayneN View Post
    ... put the steel in the jigsaw left about 1/2” overhang on one side then scribed two marks right against the base where the steel slide through and then pre-drilled a couple of holes and tapped them so that I could use the screws as stops on either side ...
    Thanks for the good ideas! The pattern bit I have could cut deeper per pass than the slender 1/4" spiral bit, shortening my time outdoors.
    The slot for the steel bar on the Bosch appears to be metric. My calipers measured 10mm x 2mm. I don't have a steel supplier in this town, but perhaps there's something in the hardware store. I know they don't have much selection in steel though.
    Hey Rhubarb9999... thanks for the encouragement to just charge ahead in a manly way. I've done manly things in the past, but this time I want to appeal to my sensitive side.
    Bill Schneider
    A dozen 5" holes...must be the braces for the Reference Recession Buster kit.
    The way I did it was make one 5" template. Use it and a pencil to draw the 12 circles. Cut out the circles with jigsaw, just inside the line.
    Then I tacked the template over the holes, one at a time, with small brads.
    Went to the router table, using a flush cutting bit, ran it around the hole to make it conform to the template. This created maybe 3/4 less dust than using a jasper jig for each hole.
    If your router table has dust collection, there won't be much for the wife to complain about.
    Sep 2008
    NE, IN
    3,366
    You must be a perfectionist if you circle-jig cut the holes in the braces!
    May 2007
    Athens, Ohio USA
    1,163
    Quote Originally Posted by pecker View Post
    Ding, Ding, Ding... we have a winner! That's exactly what it is.
    However my router table is, umm, modest, and dust collection is non-existent...
    Perfectionist? Not me, but still trying.
    Bill Schneider
    Jan 2009
    San Antonio
    18
    I've got the Bosch 1591 saw, and I made my own circle jig for it. The blank plates for an expansion slot in the PC are just a tad bit too wide, so I cut one down with a pair of tin snips and a file. I inserted it so the hook end of the plate was on the outside of the circle (left side of the saw when holding it) and drilled a hole in it for the screw to secure it. A couple more holes were drilled in the end that was sticking out to screw it to a 3/8" piece of plywood that became the radius for the circle.
    The circle I was cutting was 36", though, so rigidity wasn't critical. I'm not so sure how this method would work with a 5" circle, it might be too loose.
    Come to think of it, you can get a 5" hole saw...is there a reason not to go that way?
    Take the first pass or two with the router. Finish with the jigsaw freehand with the blade against the outside of the router-cut groove. The groove really helps you stay on course. Saves a lot of time...recently did 90 holes this way.
    No reason to bother cutting them precisely if they're just holes in a brace. Do them rough with a jigsaw, and use a small roundover bit with the router on the cut edges to clean it up. Some randomization is desirable here.
    Here's what you need
    Home Power Tools and Shop Accessories More Power Tools and Accessories Circular Saws and Accessories Jig/Circular Saw Guide Details
    Average Rating: (2 customer reviews)
    $11.99Each
    Share
    Scales on each bar provide quick and easy cutting measurement so you can establish exact distances from the blade before making any cuts.
    Trim feature allows you to change cut position by 1/16" without moving the tool.
    With pivot point holes for circular cuts.
    Includes four bars, guide head, screw and clamp (for jig saw).
    Jig-Circular Saw Guide Instructions
    this is at Rockler.com, search jigsaw guide.
    May 2007
    Athens, Ohio USA
    1,163
    Lots of good suggestions! Thanks everyone!
    I'm not entirely sure of what to do yet, but you can bet the DIY side of me will have a say.
    I'll update this thread when I arrive at something useful.
    Thanks again everyone!
    Bill Schneider
