Results 1 to 8 of 8
    Default 230 Volt sub running on 120 Volt
    Hi - I am thinking of buying a used Dali subwoofer (swa 15). This runs off of 230 Volts and I will be using it in the US where its 120 Volts. Its a 350 Watt Amp RMS with 1000 Watt peak. What type of power converter do i need to run this adequately and who makes decent ones? I trust you guys more than most. thx -yurij
    6,991
    Default Re: 230 Volt sub running on 120 Volt
    build your own. www.antekinc.com has a 120 to 230 trans that just needs the right plugs. the site is down right now I will post the full link later
    mid-CA
    52
    call electrician??
    6,991
    http://stores.shop.ebay.com/Antek-inc__W0QQ_armrsZ1
    this is their ebay link john is the owner nice seller.
    they have a 600va 120v to 230v transformer add plugs and a fuse and you are set.
    6,991
    http://cgi.ebay.com/1000VA-Toroid-Is...#ht_825wt_1167
    this is the type it is a little bigger then you need.
    he has a smaller size
    6,991
    http://www.antekinc.com/pdf/AN-64115.pdf
    this is 69 dollars and is the minimum for your amp. the plugs are around 10 bucks. it would step up from 115 to 230 volts.
    this would be a much better deal if it is well made. I just don't know the seller.at all.
    http://cgi.ebay.com/2000-W-Watt-Step...item53d9cea6ce
    Thx for the replies. So I gather there is no issue using a converter to power the sub, i just need to get the right strength converter. Building my own looks a little too bare-bones, its just a transformer (but what else do I need?). Also, since its for a sub, I don't think I need such an audio quality transformer (low frequencies leak less?), or do i? thx -yurij
    Nov 2008
    Lexington, KY
    853
    Odds are good that the existing Toroid Transformer in the amplifier can be reconfigured for 115; it's worth a look. If you've got 4 leads coming off the primary side you're set.
