Re: gluing mdf end to end?
Biscuits really help with alignment. I successfully used biscuits and Gorilla Glue on some veneered MDF enclosures that I built. I chose Gorilla Glue, because it can be cleaned off the veneer with acetone.
I often mention epoxy because it has not only superior strength, but fill properties too. Wood glue has little or no strength in a wide gap, not so with epoxy. Epoxy is way stronger than Titebond or Gorilla Glue. And if you let the epoxy overflow the glue joint, it will fill your glue joint. You will have no joint line problems other than some extra sanding to do.
Think of industrial, aerospace and military applications. Would they use wood glue or epoxy?
