Page 14 of 74 FirstFirst ... 412131415162464 ... LastLast
Results 261 to 280 of 1473
  1. #261
    16,583
    Default Re: Flex Your PCD Mettle:
    Zilch, what is the mic distance and driver placement relative to the mic location?
    I'm getting ready to PCD it and would like to get the vertical offsets from the mic location so I can see if I can pull out the Z offset from your published data.
    Schumakubin Plans
    The Fraud Continues || Hoax
  2. #262
    Once again, awesome guys!!
    Zilch, why did you choose to 1425 over the 1745? The 1745 would have been easier to manage down low.
  3. #263
    Berkeley, CA
    1,207
    Ooops, mic distance 44", c/c = 10" (I'll confirm that), and all measurements from midway between woofer and waveguide centers.
    Hi, Penn. 1425 because that's what QSC uses in 122i, no?
    [It's also cheaper.... ]
  4. #264
    16,583
    One last question.
    What's the opening diameter of the WG?
    Looks like the woofer acoustic center is about 40mm in front of the WG acoustic center.
    Schumakubin Plans
  5. #265
    New York, NY
    168
    Very cool, boys.
  6. #266
    16,583
    Quote Originally Posted by Zilch View Post
    Is there any more available from that tweeter? I'd sure like to see just a tad more output from it on the top end. Sure would make tweaking the response a bit easier.
    Schumakubin Plans
  7. #267
    Berkeley, CA
    1,207
    One last question.
    1" throat on the compression driver/waveguide.
    First shot at Z is delta 62 mm from the measured inverse null location.
  8. #268
    16,583
    Are you padding the tweeter with the L-pad to that level? Can you set it for just a tad more output at the high end?
    Schumakubin Plans
  9. #269
    Berkeley, CA
    1,207
    Yes and yes; we can probably grab as much as 1.5 dB more. It's set at 1:00, and up to 3:00 would be fine.
    C/c distance is 10.6875".
    For wavelet heads:
Name:	OLA 122i Wavelet.jpg
  10. #270
    Yeah, the 1425 is what is in the 122i, the 1745 is in the 152i but the 1745 fits the 122i waveguide also and I remember it being maybe $10 more for a better response.
    I will ship you the 1745 if you guys wanted to switch? btw, I just received some Radian 745Bs so I have a new build with rear-mounted woofers, etc.
  11. #271
    For wavelet heads:
    Cool, Im a wavelet head that geddes doesnt like
  12. #272
    Berkeley, CA
    1,207
    Default Delite 10e Second Attempt:
    Forward axis = +3.01°, drivers in-phase:
    [2:41 AM.... ]
    Vertical polar maps:
    Compare to Delite 10 w/XT1086:
    http://techtalk.parts-express.com/at...6&d=1271575232
    [W/10.69" c/c and 2.16 kHz XO, the forward lobe is getting short; still usable, though.... ]
Name:	OLA 122i 2nd Try.jpg
ID:	8840   Click image for larger version.
Name:	OLA 122i 2nd Try VPM.jpg
ID:	8841   Click image for larger version.
Name:	OLA 122i 2nd Try VPM 510.jpg
  13. #273
    New York, NY
    168
    Wow performance on a 6 buck part.
    Nice how the Celestion tapers off at the high end.
    For comparo, is red the measurement axis on the XT1086 graph?
    Thanks for doing this.
  14. #274
    Berkeley, CA
    1,207
    Quote Originally Posted by Skywave-Rider View Post
    Yes, red is the first button in CLIO, and thus, the forward axis in vertical polar maps, unless otherwise stated.
    In this case, it's +3° from the midpoint between the drivers, so the up direction runs into its null sooner (Lt. Gry).
    The PCD sim on this round is nearly perfect:
    Crossover (preliminary):
Name:	OLA 122i 2nd Try SC.jpg
ID:	8850   Click image for larger version.
Name:	Delite 10e XO.JPG
  15. #275
    Berkeley, CA
    1,207
    Pete requested some additional measurements with the L-pad set at 3:00 in lieu of 1:00, which are attached below.
    Also, here are the offsets as I presently have them, on the forward axis:
Name:	OLA 122i Dims.jpg
    Attached Files Attached Files
  16. #276
    Berkeley, CA
    1,207
    With Pete's suggested mods:
    Both drivers normal polarity.
    Forward axis moves down 0.33° @ 1:00.
Name:	OLA 122i Schumacher.jpg
  17. #277
    16,583
    Had to adjust things because I had the acoustic offset reversed, with the woofer behind the tweeter.
    Added a bit of BSC
    Woofer XO:
    1.8mH .3 Ohm
    15uF
    .4mH .2 Ohm
    Tweeter XO:
    4uF
    .15mH .2 Ohm
    3.3 uF in parallel with 1.8 Ohm before the XO.
    change 2.7uF to 3.3uF in notch circuit.
    I'm using Jeff's latest version of PCD with the corrected vertical spinners and sign switched acoustic offset.
    So 7 degrees above tweeter axis appears to be the design axis where the deep reverse null occurs.
    Schumakubin Plans
  18. #278
    Looking forward to seeing the data posted here.
    I am unfamiliar with that horn. May we have a link, please?
    Here are plots I ran today. 1 meter on axis with crossover. The composite plot is with smoothing N=3.
ID:	8879   Click image for larger version.
Name:	Ciare 1.38TW.jpg
ID:	8880   Click image for larger version.
Name:	bass reflex enclosure.jpg
  19. #279
    Berkeley, CA
    1,207
    Default Re: Design Axis:
    Our waveguide axis is 5.3438" above the midpoint between woofer and waveguide. At an 8' listening distance, that'd be arctan 5.3438/96 = 3.1860°, and at 10', 5.3438/120 = 2.5498°, assuming we are listening at waveguide height, per normal practice. That's where I target the design axis.
    Standing, I'm 22", or arctan 22/120 = 10.3889° higher at 10' listening distance.
    It'd be good if there was no hole in the response there.
    [OR at reasonable angles below the waveguide axis, either.... ]
  20. #280
    Berkeley, CA
    1,207
    That's certainly looking good, Scitizen.
    Try some off-axis measurements, say, in 10° increments; they don't tell us the dispersion pattern of that horn anywhere that I could see....
