My first Line Array
So I am going to build some sort of line array, I have found a couple designs online and I am confident I can pull this off.
I want to use 12 woofers and 12 (or more) tweeters per enclosure.
for woofers I would like to use this peerless model http://www.parts-express.com/pe/show...number=299-250
For tweeters I was thinking about using the apex Jr. tweeters or maybe some cheap piezos or something cheap that anyone would recommend.
Using these woofers and apex jr. tweeters can anyone give me an Idea where I should put the crossovers.
Re: My first Line Array
If you're going to use 6.5" woofers, you'll want to use tweeters that can reach low enough to cross with the woofers before they begin beaming around 2500Hz. That excludes all but the most expensive ribbons.
Tweeters that can do that and still pack tightly are not too common. The ND28 can be mounted pretty close together and still cross as low as 2000Hz.
If you want to use the Apex tweeters and cross higher, I'd suggest a smaller woofer.
Re: My first LA
Would this Hi-Vi 2 1/2" full range driver be suitable for LA usage from 500 Hz up with a passive crossover?
http://www.madisound.com/catalog/pro...oducts_id=8319
