Results 1 to 14 of 14
    Default Need Help Cutting MDF Boards
    Basic question for experienced woodworkers out there. I have 4-pieces of 3/4"x11"x24" mdf with "bullnose". What's the best 7-1/4" blade and method for using portable circular saw to remove bullnose 1" from edge and keep the edge straight. Should I clamp 2-pieces for 1-1/2" thick and make one pass?
    tia,
    Sid
    Aug 2009
    Toronto, Canada
    326
    Default Re: Need Help Cutting MDF Boards
    With only a portable 7 1/4 saw just cut one board at a time. Use the straight edge of the second piece tightly clamped as a guide on the top of the piece you want to cut. You will need to offset this to have the edge of the base plate of your saw set so that the blade ends up cutting where you wish.
    Measure carefully - then measure again, then measure again so that both ends of the guide piece are parallel before you make the cut.
    Don't force the saw into the cut just let it smoothly work it's way through
    btw make sure you have a new / sharp blade(carbide tip, 60 to 80 tooth blades work well for straight MDF rips) before you do the cut
    Repeat for the other piece.
    Oh and watch your fingers and the power cord of the saw
    I made a rip guide for my circular saw. You can find many instructions via google.
    Covington, KY
    299
    Thumbs up Re: Need Help Cutting MDF Boards
    Go here to make a "saw board".
    http://www.benchnotes.com/Skillsaw%2..._guide_boa.htm
    Best investment and cheapest straight edge cutting you can make with 1/8 inch Masonite (hardboard). The ADVANTAGE is that you never have to measure an offset or compensate for the blade thickness (kerf). Just place the edge against the measured line and cut.
    I have made two. One is 24 inches and the other 48 inches.
    George
    Quote Originally Posted by moosespeaker View Post
    George
    Found your tip via Google,
    Thanks Moose!
    Quote Originally Posted by MorfiusX View Post
    Right you are! Got it on Google.
    Talking Re: Need Help Cutting MDF Boards
    Quote Originally Posted by CokewithLime View Post
    Thanks for your words of wisdom. I like to keep all six of my fingers!<g>
    I learned from my dad a long,long time ago, measure twice , cut once.
    Quote Originally Posted by Sidney56450139 View Post
    Yep... but that's after you've gotten good. Most folks have to go thru many years of "measure 5-6 times, cut once" till we get there...
    no matter how many times you cut a board, it's never long enough
    Nov 2008
    Melbourne, Australia
    34
    I use a router with a flush trim bit to get the best accuracy when cutting mdf.
    Quote Originally Posted by jonpike View Post
    Can you measure too much??
    Quote Originally Posted by estreet View Post
    Well, I know it's easier to take off, but a lot harder to add to.
    BTW,
    Here's the links I googled for diy saw guides:
    This one's from George (Thanks!)
    http://wayneofthewoods.com/circular-...ing-guide.html
    Quote Originally Posted by David Gatti View Post
    Hi mate!
    If I catch the bug, I'll have to learn how to use one. There are some incredible results of fine woodworking skills displayed here.
    tia,
    Sid
    Thanks for the tips, I got 'er done! Ripped 1 inch off edge of 3/4" mdf, using trusty Irwin Quick-Grip clamps, 3/16" thk. alum. straight edge and Ryobi portable circular saw with 5-1/4" 18T carbide-tipped blade. Nice clean edge with minimum sanding requred.Careful measuring with saw cut is required to setup edge of guide. Once that's checked (twice), all boards were cut and matched exact. $0.00 spent to do the job. HomeDepot made three crosscuts (n/c) in 8ft.long bull-nosed mdf board, but could not do rips on boards only 11" wide. That's just saw dust on the edge of final cut pic.
Name:	Rip MDF_01.jpg
ID:	7462   Click image for larger version.
Name:	Rip MDF_02.jpg
ID:	7463   Click image for larger version.
Name:	Rip MDF_03.jpg
