Results 1 to 17 of 17
    Default curved bubinga ZA5 mtm
    thought I would post up some pics of the finished product, well almost finished. I have to finishe the other one this weekend.
    Check out my website: www.freewebs.com/uber-stealth.
    Now offering cnc cut baffles and other speaker cabinet parts
    wisconsin
    2,617
    Default Re: curved bubinga ZA5 mtm
    Lovely. Is that for Madisound?
    yeah, if i ever finish. I hope to finish them this weekend
    Jul 2006
    268
    Quote Originally Posted by nikbrewer View Post
    Very nice! Great work.
    DaveH
    Nov 2008
    Long Island
    709
    nice work, is that cold pressed?
    its paperbacked veneer applied with 3m water based veneer glue, i just sticket and roll it
    Nov 2008
    Long Island
    709
    looks pretty flat...
    5,741
    nics been busy. nice.
    Great looking cabs.
    Is this a new product?I needs to get me some a dat
    I have used it for several years. I will look on the bottle and get the part number. Its price, about 85$ a gallon, but it lasts me several months, so it should last the hobbiest a long time. You just applie to both surfaces, allow to dry abotu 30 min, then stick and press it hard, and its stuck and nover coming off
    Thanks nik,it sounds like it would be easier than using the PVA/ iron on method.I don't do enough veneering to need a gallon ,hopefully it's available in quart size.
    they do.
    product is 3M fastbone 30-nf contact adheasive. I used it at my old work which did commercial millwork, so it very high quality
    Jan 2009
    Wisconsin
    160
    Nice work. They look beautiful.
    Do you know if the 3M adhesive might be impervious to water? As in using water based dyes to color the wood? I know contact adhesives are susceptible to heat. I used some to put a wooden decal over my fireplace mantel frame and after about a year it kept sliding down on one side.
    not sure about the water issue, but i knoe once dry, nothing cleans it up, so it wont discove in water or any other solvent. We used this at my work because it did not react with solvent based finishes, but I would guess it would be fine with water based as well. This is not like a solvent based adheasive. All I can say is buy a small amount and try it, and you will veneer no other way
    Jan 2009
    Wisconsin
    160
    When you apply it, do you have to do like other contact cement, use an in between layer so you can correctly position the veneer? How did you place the sheets on the substrate?
    Darren
    Nik,
    Also, where can the average person pick this stuff up? I assume it's not available at HD or Lowe's.
    i order it online, just google it.
    I just over size my veneer and start at one edge and lay it down, then rub ut down hard with a piece of wood. I have never used the wax paper method, but i have seen it done. You can also use dowel rods to hold it up on larger pieces
