Results 1 to 20 of 37
    Brooklyn NY
    5,331
    Default Fountek NeoCd3.5H Horn Tweeter
    all measurements were done with 20mfd capacitor in series
    on axis response was taken on a 5'x10'
    tweeter was surface mounted.
Name:	fr 1 meter 7msc.jpg
ID:	8914   Click image for larger version.
ID:	8915   Click image for larger version.
    Brooklyn NY
    5,331
    Default Re: Fountek NeoCd3.5H Horn Tweeter
    CSD and nonlinear were taken 0.5 meter.
    Off axis response was taken at 1 meter on the 14"x14" baffle mounted on the rotating stand.
Name:	horizontal off axis 1meter 0.15,30,45,60.jpg
ID:	8917   Click image for larger version.
Name:	vertical off axis 1 meter 0,15,30,45,60.jpg
ID:	8918   Click image for larger version.
Name:	non linear.jpg
    Brooklyn NY
    5,331
    I have also measured Fountek NeoCd3.0M. If anyone is interested, I'll post it as well.
    Dec 2008
    Long Island
    4,267
    Sure, it would be an interesting comparison.
    http://www.diy-ny.com/
    Brooklyn NY
    5,331
    here it is, same conditions
    tweeter flush mounted.....was easy enough
Name:	FR 1 m  7msc  90cm.jpg
ID:	8920   Click image for larger version.
ID:	8921   Click image for larger version.
    Brooklyn NY
    5,331
Name:	1 meter 0,15,30,45,60 off axis.jpg
ID:	8923   Click image for larger version.
Name:	1 meter vertical off axis 0,15,30,45,60.jpg
ID:	8924   Click image for larger version.
    Jan 2010
    St Louis, MO
    970
    Thanks for posting the results, looks like the 3.0 is better all around. What's with that nasty energy storage at 2khz on the 3.5?
    Brooklyn NY
    5,331
    I don't know man. I was a bit surprised myself. They both have it but the horn loaded ribbon has a bigger problem, it appears.
    I am thinking LCR with second order around 2800hz should do the trick.
    3.0 got my vote as well. Few more $ but I think it's worth it.
    Minnesota
    885
    Thanks for letting us know thie information you found out.
    Jan 2010
    St Louis, MO
    970
    Yea I suppose the 3.0 is twice the price so it should be better. 2800hz would probably be fine, above 3500hz it looks great.
    Dec 2009
    Elizabethtown
    269
    Though 3.0 seem to have better response . The 3.5 still looks usable. Carpenter
    since they are fresh on your ears. Would you say the 3.5 is still a good bargain for the price?
    Brooklyn NY
    5,331
    I think 3.5 is a good tweeter. It's more limited because of the energy storage issue and nonlinear products then 3.0 The question really is, what can you use it with?
    Dome mid range or a 3" woofer with linear response extending in to 3500hz area?
    I haven't build the systems with either one yet but will soon.
    Good for the money? If used within it's limits, I guess so.
    Dec 2009
    Elizabethtown
    269
    Which are you thinking of pairing them with 1st and 3 inch woofer in a 2 way or a mid range for a 3 way?
    Actually you can also get a 4 inch woofer to reach 3500. Look at the B4n, TB titanium and bamboo drivers.
    21,576
    Is the SPL really that low on the 3.5? Or did you not have the voltage at 2.83VAC?
    *InDIYana 2016 event*
    Brooklyn NY
    5,331
    Voltage was about 1-1.5.
    18,787
    The performance above 3000Hz looks very nice. Distortion is quite low and response pretty smooth.
    Thanks for posting that data.
    Brooklyn NY
    5,331
    I am impressed with horizontal off axis of 3.0. But yeah, I think CD 3 is a new find for me and will provide for a couple of good ribbon designs. The 3.5H is good to but not as good as 3.0.
    Brooklyn NY
    5,331
    Quote Originally Posted by Pete00t View Post
    I have a couple Jordan 92s laying around and also going to build Dayton RS150 2.5 for a friend. So, that 2.5 may become 3.5 with 4 rs150 per side, and couple of dome mids with 3.5H in the center. BBMTMBB.
    [QUOTE=r-carpenter;1647369]I The question really is, what can you use it with?
    I/QUOTE]
    Given the high sensitivity, i'd pair it with a Fostex 4" fullrange as a mid crossed to the woofer section in the 5-600hz range.
    Jan 2010
    St Louis, MO
    970
    Sounds like good plans ... they'd be a nice match for the Jordans or dome mids. Best use of them looks to be crossed at 3.5khz or slightly higher.
