Results 1 to 1 of 1
    5,739
    Default woofer box and circuit.
    somthings goofy here. minimum port .03? sorry that did not work. disregard and ill try again. please delete this thread.
    Version 4.5 12/4/2009 by Jeff Bagby, Paul Verdone, and Charles Laub
    Entered Driver, Box and System Parameters Active Circuit Response Designer
    Project/Woofer Name: Dayton RSS315HO-4 Circuit / Amp Name: Dayton HPSA-500
    Driver Configuration: 2 Drivers wired in Series
    Five Band Parametric Bass Equalizer
    Woofer Parameters Band 1 2 3 4 5
    Fs (Hz) 37.50 Standard Box Alignments Fc 20 Hz 31 Hz 40 Hz 63 Hz 80 Hz
    Re (ohms) 3.70 Standard Vab (liters) 8.78
    Le (mH) 0.53 Vented Fb (Hz) 61.85 Gain (dB) 6.0 0.0 0.0 0.0 0.0
    Vas (liters) 25.60 Entered Box Parameters
    Qes 0.280 Vb (liters) 24.00 Q 1 1 1 1 1
    Qms 1.52 Vb (Ft^3) 0.85
    Sd (cm2) 0.0132 Ql (Box Losses) 30.0
    Xmax (mm) 5 Qa (Absorption) 100 Selectable Textbook High Pass Filter
    Series R (Ohms) 0 Fb (Hz) 50.21 Fc Selected Textbook Response
    Dv (in) 3 60 Hz Second Order Butterworth
    Number of Vents 1
    0 Lv (in) 6.68
    Available Power (W) 2 Qp (Port Losses) 100 Optional Second Order Adjustable High Pass Filter - Stage One
    Fc Q Gain (dB)
    4.9 4.90 24 Hz 2 6.0 dB
    972 70451032.32
    830 1050.20 Optional Second Order Adjustable High Pass Filter - Stage Two
    1050.2 100.00 Fc Q Gain (dB)
    52 24.34 14 Hz 0.7 -3.1 dB
    27 50.21
    1 24119497.153
    1.21 0.000 Selectable Textbook Low Pass Filter
    0 Qb (Total Box Q) 18.75 Fc Selected Textbook Response
    700 Hz Third Order Butterworth
    Derived Driver, Box and System Data
    Calculated Driver Parameters Calculated Alignment Data Linkwitz Transform - Biquad Pole Shifter
    SPL 1 W / Meter (dB) 91.77 0.419 F0 Q0 Fp Qp Gain (dB)
    SPL 2.83V / Meter (dB) 92.11 66.38 41 Hz 0.642 20 Hz 0.7 12.6 dB
    System DCR (Ohms) 7.40 Alignment Value 8.38
    Applied Voltage (V) 3.89 EBP (Fs/Qes) 133.93
    Efficiency No (%) 0.927% h (Vas/Vab) 2.13
    Qts (with series R) 0.236 alpha (Fb/Fs) 1.34
    Cms (mm/N) 52304843.836 Port Min Dia (in) 0.03
    Mms (kg) 0.000 Max Output W/ Filter 94.09
    Rms (kg/s) 0.000 Relative -3 dB Point 62.17 Hz
    BL (kgm/sq) 0.001 Relative -6 dB Point 51.22 Hz
    Max Output (dB) 94.87 Relative -10 dB Point 45.85 Hz
    Box Volume And Vent Calculator
    Height (Outside Dim) 8.5
    Width (Outside Dim) 21
    Depth (Outside Dim) 12 Frequency Range Utility
    Wall Thickness 0.5 Port Diameter 1.5 1.5 Minimum 10 Hz Maximum 10,000 Hz
    Baffle Thickness 0.75 Port Length 3 10 10000
    Volume - Vab (Liters) 26.23 Number of Ports 2 Graphics Save Utility
    Volume - Vab (Ft^3) 0.93 Tuned Port Fb 50.1 Hz Graph Width Multiplier 1.33 Height Multiplier 1
    Quick Tuning Utility Bar
    Adjust Vab: 24. L Adjust Fb: 50.2 Hz Adjust PR Mass: 1050 g Adjust Ql: 30
    0
    0
    0
    0
    0
