Results 1 to 10 of 10
    Default SPL trace. Will not find my .JPG file
    I have tried right click>copy, ctrl+C, etc, nothing works..... Can anyone help? I am trying to map my calibration sheet on a mic a received from PE.
    Dec 2009
    Seattle, WA
    145
    Default Re: SPL trace. Will not find my .JPG file
    Quote Originally Posted by fastline View Post
    From MS Paint (assuming you're using Windows), use the "Select All" and "Copy" menu commands, then paste into the SPL trace app.
    16,583
    Or simply hold alt-prt screen. Then the active window is copied into clipboard.
    Schumakubin Plans
    The Fraud Continues || Hoax
    I am with you right up until "paste". where am I supposed to paste it? You cannot right click in SPLtrace to paste anything. Maybe I need spoon fed on this one...
    Dec 2009
    Seattle, WA
    145
    Use the menu command. If the buffer contains data, the option to paste will be enabled.
    I have tried about everything... the only options in file dropdown is import file, save as, and exit. import file only wants to use clipboard and when I try it, it indicates to copy something to the clipboard even though it is already there.
    Is it possible I do not have the software loaded right? Seems to be fine but next to no options with it. I cannot right click anywhere. Really want to get this working but something does not seem to be right..
    Hah, I got it to do something but image looks rather squashed. I used ctrl+ print screen in paint. Nothing else seems to work...
    Also cannot seem to get it cleared out to try another image. Keeps going back to the same image...
    Dec 2009
    Seattle, WA
    145
    I suggest you save the curve as a file then use MS Paint (or another app) to crop just the curve portion that you want to trace. That way the image will not appear "squashed" in the SPL trace app. An alternative is to use a screen capture utility that will allow you to select just a portion of the screen - I use "FastStone capture" and recommend it.
    Hope this helps.
    OK, I FINALLY got what I wanted in SPLtrace. I am working with it now to see if I can generate the file I desire.
    Thanks guys!!!
    Jun 2009
    Minneapolis
    2,114
    Glad you got it working. I was going to ask if you had dual monitors .. that'll overflow the program every time on a prntscrn
