Impedance phase
What options do I have to fix my impedance phase? It dips too low at the xo point.
Don't even try
to sort out the lies
Re: Impedance phase
Stay away from tube amps and I bet you will be fine
Re: Impedance phase
+1
Look at the impedance phase around the woofer resonance. It's no big deal.
Modern amps with low output impedance won't have a problem with your XO, as long as the impedance doesn't dip too low.
Re: Impedance phase
What impedance and how much phase angle are we talking about?
Re: Impedance phase
At about 2khz it dips down to slightly below -60 degrees. Wolf's blog says keep it between +\- 30 if possible, and says some amps may have a problem with going further than -60.
(Thanks for the quick replies.)
Don't even try
Re: Impedance phase
Lesser amps with marginal stability might have a problem.
But most won't, as long as the impedance doesn't dip too low.
Re: Impedance phase
Yes, but what's the impedance when it hits -60 degrees? It's the combination that matters. If it is -60 degrees and 20 ohms, it probably won't make much difference. If it is -60 degrees and 4 ohms, it will be much harder to drive at that frequency.
Re: Impedance phase
How's that? Most of my amps are rated at 8 ohms and I would expect them to run these without shutting down or smoking. (I've used these amps to drive 4 ohm loads plenty, even car subs, as long as I keep the volume reasonable)
Don't even try
Re: Impedance phase
Ok, so assuming that chart is ok then all is good.
But if it's not ok, what are my options? Nothing I've tried so far in the tweeter circuit has changed this impedance phase issue, including changing the tweeter and nuking it's fs impedance. Reducing the L and/or C in the woofer circuit fixes everything right up, but the values I am using for L and C are important for my xo. Using a parellel resistor on the woofer works too but I think that's a fire hazard. Flattening the woofer impedance by other means will probably work but I'm not sure where resistors can be safely used in a woofer circuit. I assume the problem here is the massive impedance spike at about 1khz but I'm not sure how to safely tame that (without starting a fire).
Don't even try
Re: Impedance phase
LRC series notch across the entire crossover at the peak frequency will pull the impedance down. Not sure what that'll do the the electrical phase above there, but it should not affect the frequency response....
Re: Impedance phase
Thanks for the response. I have 2 questions.
1. Based on the graph I posted, is this necessary?
2. How do you enter this into PCD? (As far as I can tell it has to be entered into the woofer low pass section or the tweeter high pass section, I don't see a section for applying a notch to the whole crossover.)
Don't even try
Re: Impedance phase
http://techtalk.parts-express.com/sh...d.php?t=220355
For a look at the design I'm talking about, check the link above.
Don't even try
Re: Impedance phase
I believe if you scroll to the right of the PCD you will see the area where you can enter the LCR values for the whole circuit.
Re: Impedance phase
Your impedance is fine. Z is still relatively high when presented with this capacitive load.
Re: Impedance phase
Don't even try
