mids Tang Band W2-803SM or the Tang Band W2-800SL 2?
Thinking about a 3 way design. Which do you think would be a better mid range the Tang Band W2-803SM or the Tang Band W2-800SL 2? Also how reliable are TB's graphs?
Re: mids Tang Band W2-803SM or the Tang Band W2-800SL 2?
I would use the 803 over the 800, due to the longer throw surround, the phase plug for power handling, polycone fr more benign response curve, and the higher Qts for a more feasible sealed alignment. The 800 SL might want you to vent it, depending on alignment.
If you want .zma and .frd for the 803, just holler...Beware of a higher Fs for both drivers too. My 803 pair came out about 214/215 Hz.
Wolf, what is your take on this little TB 2" driver?
http://www.parts-express.com/pe/show...number=264-808
I had some at one time.
I have been told that they don't sound very good, unless treated very carefully- like steeply highpassed. To me- they look like the least of the 2" line from TB.
The 803Sm and -1767 can take a lot more abuse. I tend to stay away from the older S-surround 2" from TB, as they are a lot older design, and are probably outdated considering the new stuff. I know they didn't take bass as well as the 803 and 1767, so take that as you may.
You know know my e-mail send away. Maybe the Tang Band W2-748SG 2 is also worth another look as well
I've actually heald one of those, and it didn't look to me to be a very nice unit. It also has that S-surround that I don't trust much. The Xmax is a bit shorter too, so it won't handle as much power. The Qts is very low, wanting a horn or vented cabinet, unless you highpass steeply. Last I knew it was not a metal cone at all either. The pdf confirms it's just a poly too. Then if you look at the FR, it rolls off fairly fast below 1k, so it's really limited as a mid anyway.
My 2c,
Would you believe I disagree? (get ready for the symphony)
If he were using them as a tweeter, I wouldn't....but he intends them as a mid. Therefore I think the larger Sd of the parabolic 800 may trump any of the 803 phase plug heat wicking benefit. Plus the 800 aluminum cone actually acts as a sink as well (neither is exactly HO, so I hope this is a smallish 3 way).
I would say tweet - 803, but mid - 800. My 2c
cheers,
AJ
You are entitled to your opinion, but I hold little faith in the S-surround.
Too bad that larger Sd only gets you one more dB of extra sensitivity.
I have plans for a pair of W2-800SLs that I have lying around: will use them as a tweeter in a 2-way with an 8" or 10" woofer, crossed over around 800 Hz. Something along the lines of a mini tower, I guess.
Although I have not seen off axis data on the driver I believe, based on my experience with other small inverted dome drivers, that the dispersion will be wide enough allow the 800SL to be used as a tweeter, at least up to the mid teens. That's good enough for my design goal for this speaker, because I have put emphasis on a low crossover point and low order (2nd) crossover. The 800SL has enough radiating area and Xmax to pull it off.
There is another 2" inverted dome by TB, the W2-748SG:
http://www.parts-express.com/pe/show...number=264-861
It might also make a workable tweeter capable of a low crossover point.
Wolf - can you go in to more detail about your opinion of the TB surround?
-Charlie
-Charlie[/QUOTE]
It's a very small S curve, and some other older units were even "R-shaped", as they called them. I've held the -748, but not the 800SL. FWIW- it really limits the 'ease of travel', sortof like the cloth for pro drivers, or even a really stiff spider. The suspension on the -748 was *very* tight. I would say it's more similar to the cheap Radio Shack 2.5" mini-speaker than a true wide-range 2" driver.
To me, in a wideband driver you want the control, don't get me wrong, but ease of movement can help 'openness' in the midrange. I know I'm not using technical terms here, but that's my experience.
Also- be advised the -748 is a poly-mica, and not at all a metal cone, like the PE ad-copy reads for it.
Take that as you may, Chuck!
Wolf, what is your take on this TB driver.
http://www.parts-express.com/pe/show...number=264-812
I can get a pair at a good price. Just do not know if I should.
I was approached by my significant other. She asked why cant i use the drivers i already have for a project. We're hopefully moving in the spring so i know she doesnt want a large inventory to move with us. So to turn this thread in another direction.
I have appreciated all the response and thanks again Wolf for the files. Can any of the tb mids, or full ranges be used as a mid tweeter or mid range for the fountek Neo 1.5. They would have to reach 4000 to 4500?
Most of the 3" conical drivers will reach that high without issues. It's if you can have the sensitivity you need that is the question. Don't use the -315 for that though. There is a not-so-nice suckout around 3k that makes that difficult.
W3-881 (benign poly-cone, and very smooth and flat respsonse),
W4-1052 (much overlooked, but a well-designed low mass cone. Has a dip that could become a problem: http://i18.photobucket.com/albums/b1..._W4-1052SA.jpg),
W3-1364 (flat according to zaph's measurements, and is usable where it counts for you),
W3-1878 (looks immensely flat on TB's plot, and has higher sensitivity than most of the lot),
W3-593SF (classic 871 but in a lower aesthetic factor),
W3-1335SB (resonance of metal, but definitely will work, and is easily compensated. Should sound as clean as W4-1337.),
W3-1797 (use a BS4 with this and avoid the energy at 4k a bit. IMO- this is your best option in a 3" for that ribbon from TB.)
Just be sure to xover above 250/300 Hz to avoid Xmax issues with most of the above.
Personally, the W3-881 (for zeek) is a very nice little wide-ranger, but filter out the bass. I heard them in Chad Gray's 'Olives' back in Dayton 05 as I recall.
http://chadgray.info/projectdetail.cfm?ProjectID=48
He used them all the way up, and it was nice!
Hope that helps!
