Results 1 to 10 of 10
    Salmon Arm, BC
    472
    Default Go
    in a 2 channel system, is it possible to get SQ from a transport (w/DAC) in an HTPC that would rival a decent cd player? does anything need to be done to the audio signal in the pc to obtain this?
    i have xp home, vista and win 7 to work with in case there are differences in audio signal.
    david
    ________
    New Jersey Marijuana Dispensaries
    Dec 2008
    St. Augustine, Florida
    261
    Default Re: Disc transport in HTPC equal to CD player?
    It all sounds the same these days,
    so the answer is yes it will, be just as good as a cd player.
    Should be better for many reasons but that would require the HTPC to sound different than the CD player which cannot be proven in a DBT ABX test.
    so, again yes is the answer.
    1 tip, get a liquid cooled board or be aware that your PC's fan noise could be an issue....but since you're using the HTPC designation you have already likely addressed this.
    My setup (PC AT&T Optical out---Genesis Acoustical lens or Apogee Big Ben then Cambridge DAC or Surround processor)
    Yeah I built a couple speakers....
    Salmon Arm, BC
    472
    Default Go
    thanks.
    i remember reading that the audio signal path (in xp, i think) has some issues that can be dealt with in the pc design but i don't know/remember what they were.
    is xp, win7, etc. better than another for audio?
    david
    ________
    SIDE EFFECTS OF WELLBUTRIN
    18,779
    Don't use the CD transport to listen to music.
    Instead, rip everything to your hard disk drive with Exact Audio Copy and then stream data from the HDD instead of the CD. Read rates are orders of magnitude faster, and absolutely zero data errors due to smudges, fingerprints, scratches, jitter, etc.
    D/A converters in the more respectable sound cards (ASUS comes to mind) are the equal of most any CD player you can buy, running 24-bit 192KHz audio.
    Vista and Win7 both handle audio without the limitations of XP. However, the ASIO enabled stuff works well in XP.
    Salmon Arm, BC
    472
    Default Go
    thanks Pete.
    99% of my library is ripped but still the odd disc comes along that i would like to pop in and hear.
    can you explain these limitations in xp and how to eleviate them?
    if i use a usb dac, i don't need a sound card, do i? or is there a prefered method?
    david
    ________
    Buy glass pipes
    Chicagoland
    5,238
    My laptop is my CD player, running through an M-Audio audiophile USB. I actually auditioned several CD players before ending up at this point, too! I don't know of any audio signal path issues with XP. The one suggestion I'd make is to run some sort of utility on your HTPC to slow down the CD-ROM drive. They run way faster than they need to for audio, and thus end up sounding like a jet taking off. These utilities are freeware.
    If you find yourself going through houseware stores looking for things that would make good speaker enclosures, that's when you're addicted.
    Twitter? @undefinition1
    Dec 2008
    Long Island
    4,265
    What DAC/Sound Card are you using?
    http://www.diy-ny.com/
    Quote Originally Posted by blue934 View Post
    thanks Pete.
    david
    A usb DAC will have line level analog output, so no you do not need a sound card.
    I saw a good quick primer with some helpful links recently at http://www.empiricalaudio.com/computer-audio/
    Mostly in XP you MUST bypass KMIXER, and of course never use Windows Media Player.
    The above link suggests dbpoweramp pro for ripping, I know nothing about it but I do give a total thumbs up on Exact Audio Copy for ripping for free.
    Salmon Arm, BC
    472
    Default Go
    Face, haven't finished the build yet, still gathering data so no dac or card at the moment.
    Selder, the KMIXER was what i had read about earlier but i forgot what it was. what is it and what does it do wrong?
    i currently use win media player in my office, what is the problem with it?
    david
    ________
    VOLCANO VAPORIZERS
    Dec 2008
    Long Island
    4,265
    If you use Foobar, Media Monkey, or J. River it's easy to bypass Windows processing with ASIO(or ASIO4ALL) drivers.
    I find Foobar the easiest to use overall, but J. River has the nicest interface and is the most versatile.
    If you decide to use an external DAC, check out the hiFace Asynchronous USB interface for a jitter free connection: http://www.computeraudiophile.com/co...nverter-Review
