Trapezoid knock-down volume question
Hi all,
I asked this question in the PE cabs thread but got no response. I'm a total noob at this. For the Dayton 12" driver, the calculator's telling me to build a ported cabinet of 5.8 cu ft, or a sealed box of about 2.7 cu ft. The trapezoid kit is 1.65 cu ft. How does that work? What am I giving up going with this kit?
Thanks!
Re: Trapezoid knock-down volume question
 Originally Posted by MysteryCat
Hi all,
Thanks!
Does the calculator compensate for stuffing?
Stuffing like fibreglass increases the internal volume (25-35%) minus driver displacement (bout .15 cubes)...
Also, if going sealed - where the dip in the lower frequency on the box calculator look for the F3 - F6 point on the chart and that'll be your sub woofer setpoint for you to start out with.
 Originally Posted by rudyjakubin
Stuffing like fibreglass increases the internal volume (25-35%) .
Stuffing lowers Q of a sealed cab when the Q is well over .8, and it won't lower the Q enough to give the same F3 as a box 25-35% larger. Maybe 20%, and that lowering of Q is accompanied by a loss of broadband sensitivity.
Model the driver in that size box and you'll see. Some low end extension loss is the trade off for a smaller box.
Stuffing like fibreglass increases the internal volume (25-35%) minus driver displacement (bout .5 cubes)...
This is an honest question... you'd figure 0.5 cu ft for the driver displacement of a 12" Dayton Sub? I don't know exactly which Dayton driver the OP is referring to, but I'm thinking about the RSS315 for example. I would only figure about 0.15-0.2 cu ft in driver displacement. What's the rationale/your method for figuring driver displacement?
sorry for the incomplete info... The driver is Dayton DC300-8. I used the calculator here: http://www.diyaudioandvideo.com/Calculator/Box/
It looks very simple, so probably not taking stuffing into account. I saw that driver and the trap cabinet kit used in Econowave standard kit. I just wonder how that would work.
The trap cabinets work fine. There are many examples for the Econowave. See my post in the tower cabinets thread:
http://techtalk.parts-express.com/sh...7&postcount=31
-Charlie
That will give you the 'ideal' box size based on the driver specs, but 'ideal' means 'as good as can be got', which doesn't tell you all that much. A true box program like WinISD Alpha Pro will give you everything you need to know, with a dozen graph options.
Awesome. I'll check it out. Thanks!
