Page 1 of 4 123 ... LastLast
Results 1 to 20 of 73
    Jan 2011
    Eastern-Iown, Right off of I-80
    7
    7
    Default Best Glue/Adhesive for Cabinets/Enclosures?
    All~
    As I am a Newb~ at all of this I though it wise to solicit your advice.
    What is the best Glue or Adhesive to use when making the Cabinets/Enclosures for Speakers?
    I am not sure if it matters but you can assume that I will be using 1.0-inch thick Med-Density Fiberboard (MDF) for my projects. [because I actually will ]
    Thank you all.
    ~5UP3RT0X1N
    Just Remember: The NEWBIES are the Future of Everything.
    ~ 5UP3RT0X1N [IT-Tech & Geek-Ninja]
    Default Re: Best Glue/Adhesive for Cabinets/Enclosures?
    Any good wood glue will work fine.
    I personally use Titebond.
    Apr 2008
    Dallas, Texas
    445
    Quote Originally Posted by Southpaw View Post
    Yep. There is no need to get fancy. Titebond in a decent joint is stronger than the MDF. Glue up a test joint and break it. It should fail in the MDF near the joint, not in the glue. -- Doug
    21,559
    I've used Elmer's/Gorilla polyurethane glue, Elmer's school-glue, Elmer's wood glue, and all 3 work well.
    *InDIYana 2016 event*
    Dec 2010
    Great Smoky Mountains
    There's a reason why Elmers and Tite-Bond, among others offer 3 main types of PVA glue.
    The ordinary white has the least resistance to glue line creep but offers a long open time, good for the less-than-adept builder. (Don't even open the glue bottle before you do a dry run through with all your cauls and clamps)
    Yellow Type 2 is no stronger than the white but has more moisture resistance; the downside is a very short 5 minute open time. Good for sign-makers, bad for carpenters.
    Tite Bond 3 offers better resistance to glue-line creep, good moisture resistance and a longer 10 minute open time. The extra $$$ for hobby builders is a non-issue unless you order it in the convenient 55 gallon drum size.
    Moving to Urethane glue, Gorilla is garbage! PL-200 and it's construction adhesive brethren are kick-*** great especially for complex glue-ups like those cute Japanese front-loaded horns where no clamp dares to go.
    If all I had was white Elmers Carpenters Glue I could happily build anything you want.
    Regardless which PVA you choose, for MDF, Particle Board or Plywood, dilute it 50/50 with water and spread it on the joint prior (allow it to dry) to glue-up.
    8,073
    titebond II for everthing wood. construction adhieseve for ports. even use it as caulk.
    Brooklyn NY
    5,315
    http://www.titebond.com/IntroPageTB.....asp?prodcat=1
    I use Type II for all woodwork, some veneering.
    Mar 2010
    North Texas, USA
    3,914
    Not necessary or recommended. Weakens the joint. Both sides of the joint should have glue applied, but dilution or drying is not needed for the Titebonds or similar. Polyurethanes do generally need the surface wetted prior to application.
    Quote Originally Posted by 450VoltsDC View Post
    7,507
    If your parts cutting and joinery are perfect you can use just about anything already mentioned. If not there's nothing else that matches this:
    http://www.loctiteproducts.com/p/12/...n-Adhesive.htm
    Dec 2008
    Long Island
    4,264
    Depends on the application, either Titebond II or III.
    http://www.diy-ny.com/
    Sep 2010
    Canton, OH
    1,556
    titebond II
    I'll second that. How are your wood working skills and the tools you have at your disposal. If you're decent with your hands and have a table saw and are capable of making accurate, straight cuts that fit properly, Titebond II or III would be great choice. If your skills aren't all that, or you'll be using a circular saw without a fence guide or a jig saw for your cuts, you'll want a polyurethane construction adhesive, like the PL Premium Mr. Bill suggested, it's excellent stuff.
    +1
    Strongly disagree.
    Apply wood glue full strength to both surfaces, then clamp.
    Sealing the surface with a diluted mixture, allowing it to dry, then adding more glue and clamping seems like a terrible idea... your actual clamped glue would be adhering to hardened glue, not the material itself. Can't imagine why you would do this.
    Form does not follow function
    Titebond III for everything.
    Although I can't actually claim better results than Titebond I or II (I haven't done testing), I figure spend a buck or two more and get the good stuff.
    Relative to the other costs, a $9 bottle of Titebond III is not a big deal.
    Mar 2010
    North Texas, USA
    3,914
    Titebond III gives you longer working time. Joint strength about the same as II.
    Oct 2010
    Central New Jersey
    103
    PL 400 Poly is the strongest glue I ever used and don't let it dry on your skin you will be picking it off for weeks.Ask me how I know.There is no wood in the world stronger than a glue joint made with PL400 Polyurethane.
    Unless you are building giant Altec 210 cabs Titebond II is good enough for small to medium sized enclosures though.
    ~ Mankind's Great Problem Is A Perfection Of Means But A Confusion Of Ends ~ Einstein
    Jan 2011
    7
    7
    WOW~
    That is a lot of responses.
    Sounds like the general consensus is Tite-bond II or III would probably be appropriate.
    Since the current project is relatively small I will try out one of those based on what I can get from the Local LOWE'S.
    Thank you all for your input.
    Of-course you can expect me to ask more questions of the "basic" level nature.
    If you want to see what I am working on I have started a Blog called: "Sony-Speaker Re-Build [v1.0]"
    Agreed.
    Far more important than the adhesive you choose is the accuracy of the mating parts.
    Square up that table saw blade! Not with the dial, but with a real square.
    Having a good bracing structure in your cabinets will help a lot too. Not only does it reduce cabinet resonance, but it also greatly spreads out the load.
