Results 1 to 14 of 14
    Default (IB) Battle of the 8” buyout subs... need a decision
    First off I realize 299-246 is NLA (unless you already have a pair)
    I was hoping to get some input regarding these 2 8” subs in an IB setup. I don’t have any specific questions except for which one would be “better” (I know that is a wide open question w/o being more specific).
    I understand that there is some confusion as to whether 299-094’s Xmax (one way) is 5mm or 12mm, let’s assume it’s 12mm for this case.
    So in an IB app, w/ eq as an option and employed up to 200 Hz (max), is there a clear winner?
    http://www.parts-express.com/pe/show...46&FTR=299-246
    http://www.parts-express.com/pe/show...number=299-094
    Last edited by aarond; 02-06-2011 at 03:47 PM. Reason: to correct quoted Xmax spec to 12mm
    Aaron
    Default Re: (IB) Battle of the 8” buyout subs... need a decision
    299-094 Whoa now how did i miss these guys... Do they really have over 20mm way throw? Or did i miss understand Aaron?
    The alleged Adire sub isn't advertised as 24mm of Xmax, either. It was advertised as 24mm p-p, which means 12mm. In any event, without knowing the method with which the Xmax parameter was derived (especially on an underhung driver), Xmax specifications are not really useful.
    Facebook
    *Gort
    Aug 2009
    Ohio
    1,063
    I wish there is some information about the upper end response as well. If it is indeed flat to 2000 hz then it will be a good candidate for replacing an 8-inch vintage acoustic suspension woofer(like AR 4,6,7 and 18), becasue its foam surround is about to fall off or is already rotten. At roughly the same price of a pair foams you get a pair of nice woofer like this. BTW, the frange of this woofer is the same as the AR 8-inch woofer as well as the 8-inch from EPI, Advent and many others
    Orchard Park, New York (Buffalo)
    257
    here is the 10" version too. I wonder what they came out of, its only 8 mm on the 10 it says so maybe at 5mm on the 8 is correct
    http://www.parts-express.com/pe/show...number=299-096
    Jul 2006
    Davis, CA
    1,855
    Quote Originally Posted by hasekisgod View Post
    There is absolutely no way a $17, 8" driver has 24mm of Xmax!!! The spider would need to be wider than the driver diameter!
    -Charlie
    Quote Originally Posted by trevorg View Post
    As JR pointed out (quoted below) I was mistanken when I said 24mm Xmax, I should have said 12mm (that's what I get for posting when I should have gone to bed).
    Any posts after JR's seem mostly centered on topics that are discussed more in depth in this thread (re Xmax you really only need to read the 1st page):
    http://techtalk.parts-express.com/sh...d.php?t=222813
    So back to my original question... btw the two mentioned which is a better candidate for IB use?
    Aaron
    Aaron, I would personally go with the Adire (Adire clone?) unit.
    Facebook
    *Gort
    257
    what one is the clone from adire?
    299-094. I think the jury is still out if this is actually an Adire driver or not. I think it probably is.
    Facebook
    *Gort
    Anyone have one in the Seattle area? I'll check it out (or buy it from you) and confirm...
    257
    dan the man, i have one apart that had a bent frame. i can take pix if u like. it looks like yur design. i have the 10" and on the outside of the box says adire audio under the white sticker.
    Quote Originally Posted by DanWiggins View Post
    Thanks! I'd need to take it apart to confirm it was, in fact, and XBL woofer. Need to probe the pole and the top plate stack to confirm gaps in there...
    If you want, I'd buy it from you (full price you paid, plus shipping) and you could send it to me, I'll disassemble, and confirm for everyone.
    257
    can u email your address. I will send it to u. U dont have to pay me, your doing this for us. I went a lil crazy and bought 20 of them. dont know what im goin to do with them yet if they are good enough I would like to do maybe 6 or 8 woofers per tower in a two channel set up. Well thats a plan
