Results 1 to 4 of 4
    Default FS: QSC GX3 Power Amp w/Extended Warranty
    I have a clean condition QSC GX3 Class AB Power Amp with a transferable 6 yr warranty (activated 9/09). $200 plus shipping from 33434. The warranty alone cost me a hundred bucks when I purchased it.
    Built like a tank and much better SQ than most pro sound amps, due to class A/B circutry. Has been used to power the high frequency side of an open back audiophile set-up. I unplugged the fan quick connect as it wasn't needed for my application and wanted to reduce fan noise for 2 channel listening. Never had any heat issues and the fan can be plugged back in at any time w/o voiding warranty.
    Manufacturer's Specs
    - 8 Ohms / both channels driven: 300 Watts
    - 8 Ohms / single channel driven: 350 Watts
    - 4 Ohms / both channels driven: 425 Watts
    - 4 Ohms / single channel driven: 500 Watts
    - 2 Ohms / both channels driven: 200 Watts
    Distortion:
    - 8 Ohms: less than 0.05%
    - 4 Ohms: less than 0.1%
    Signal to Noise (20 Hz - 20 kHz): 100 dB
    Input Sensitivity: 1.2 Vrms
    Voltage Gain (8 Ohms): 32.2 dB
    Output Circuitry: Class B
    Power Requirements: 6.3A
    Frequency Response: 20 Hz - 20 kHz, +0, 1 dB
    Dynamic Headroom (4 Ohms): 2 dB
    Damping Factor: 100
    Input Impedance: Greater than 20k (balanced)
Name:	gx3 front.jpg
ID:	14175   Click image for larger version.
    Iowa City, Iowa
    227
    Default Re: FS: QSC GX3 Power Amp w/Extended Warranty
    May be interested. Where did you purchase from? A stock, B stock, C stock?
    email at jacobbirkholz at hotmail dot com for quickest communication
    Jake
    The amp was purchased from my local Guitar Center as an open box item, which is why I purchased the additional warranty. I have all the original packing materials, manufacturers box, manual, etc.
    If you purchase it, you would go onto the QSC website and transfer the extended warranty to your name. There are 3+ years remaining on the warranty. The amp is in great condition and no warranty service has ever been required.
    Thanks for your questions.
    sold!
