Results 1 to 20 of 25
    Oct 2008
    1,070
    Default Surface Mount Woofers...
    The Peerless SDS "style" has really gotten me hooked on surface mount woofers, which don't have to be rebutted/recessed/flush-mounted.
    I've noticed a few others, such as the Dayton ND105-4, and some of the GRS (but those have other problems that would keep me from using them), also have the thin, surface mount style of frame.
    What other popular drivers have this style?
    16,578
    Default Re: Surface Mount Woofers...
    Quote Originally Posted by rogoll View Post
    The DA series have very thin flanges and work just fine surface or flush mounted.
    Schumakubin Plans
    The Fraud Continues || Hoax
    Oct 2008
    1,070
    Pete, I'm sorry, but when you say "DA", are you referring to Dayton Audio?
    16,578
    DA135, DA175, DA270 etc.
    Schumakubin Plans
    Dayton's silver alu. coned woofers, cheaper than the RS series.
    http://www.parts-express.com/pe/show...number=295-335
    Jan 2011
    Colorado Springs, CO
    494
    Is there a standard or "rule of thumb" for the a max thickness of the flange allowing for an acceptable surface mount application?
    Jason
    16,578
    Quote Originally Posted by RINNAV View Post
    Jason
    I think it's more a matter of looks than anything else.
    There will be an impact on diffraction from the tweeter, but because the surface is curved, the diffraction spectrum spreads, reducing the size of peaks and valleys. Some of the beefier models, have rather thick flanges which will look rather odd being surface mounted, as well as causing more diffraction, and for those, recessed mounting is preferred.
    Schumakubin Plans
    Canton, MA
    2,613
    Jason
    I've done a lot of testing of drivers and diffraction in measurements. There are few cases where surface mounting is actually significantly detrimental vs. flush mount. It is almost never the case for the driver itself. Midrange units maybe 4" and smaller should be flush mounted. My latest system uses a Scan-Speak 15w/4531 surface mounted. There isn't any significant diffraction of the 15w response to this due to both driver directivity change and the typical lowpass used.
    The bigger issue is diffraction of the tweeter's response. Since most drivers have round flanges that varies the distance from tweeter to next driver frame rapidly, the overall impact of surface mounting is also very small. It changes with angle as well, of course.
    The more important aspect is changed little with flush mounting and that is the diffraction of the tweeter response caused by the diaphragm of the next nearest driver. It's a large cavity and its impact is orders of magnitude larger the the side edge from the frame of a surface mounted driver, hence my consistent use of felt between tweeter and next driver for diffraction control.
    IMO there's too much concern for some of the small factors and not enough for the large ones, this being a case in point. In addition, surface mounting in most cases is a minor aid to reducing relative acoustic offset.
    dlr
    p.s. Hi Pete, I see that we were typing at the same time.
    B.C. Canada
    323
    GR Research woofers are intended to be surface mounted.
    david
    Kokomo, Indiana
    7,237
    Quote Originally Posted by blue934 View Post
    david
    That may be true, but it doesn't change the fact that it will create some diffraction effects in the tweeter's response it it is nearby.
    Now, how audible this diffraction is, is another matter.
    16,578
    And as David pointed out, cavity resonance from the nearby cone woofer will dwarf any flange related diffraction effects on the tweeter response.
    Schumakubin Plans
    5,733
    i would think the thicker the flange, the greater the defraction. on a mtm i suppose it might be benificial. the da 175 in my avitar ar surface mounted.
    Canton, MA
    2,613
    Jeff, the diffraction from the flange, especially on-axis, measures minimally.
    dlr
    Canton, MA
    2,613
    david
    IIRC all Dynaudio woofers and midwoofers were designed to be surface mounted as well. I flush-mounted mine when I started (my first systems used these), but today I would surface mount them.
    dlr
    Quote Originally Posted by dlr View Post
    So how much felt is needed to control the diffraction in the tweeter response that is caused by the cavity of the next nearest driver(s)? Say in a typical tweeter crossover of around 2kHz next to a 5" midwoofer and in general terms for the felt to be effective, what minimum thickness and space is required to the next nearest driver? Thanks.
    Canton, MA
    2,613
    Quote Originally Posted by raiderone View Post
    1/2" thick x 1/2" wide x 5" long gives good results. Best results are with 1" thick x 1" wide, but you very quickly hit the point of diminishing returns. SAE F-11 is best but F-13 is still very good. I usually cut the length to match the diameter, but this isn't strictly necessary, it just has to be long enough to occlude the woofer from the tweeter's "perspective" so-to-speak.
    dlr
    dlr
    I believe its on the Zaph Audio site where there are tests measuring the effect of diffraction and demonstrates that for tweeters and midwoofers not flush mounting effects the response negatively and significantly. Flush mounting was not developed in order to make speakers look better as almost all non-audiophiles leave the grills on anyway. Also, felt tweeter rings are tested and shown to have negative effects. Now, thicker felt, as discussed here, can be used for positive effect, perhaps preventing diffraction. There is no need to flush mount subs though, mine aren't. I'll keep flush mounting until there's data contradicting that on Zaph Audio. John Krutke is not one to fall for myths, although I don't agree with him about everything.
    Oakland, Calif.
    961
    5
    Quote Originally Posted by Theresa View Post
    I'm a Zaph fan, too; but dlr (a.k.a. Dave L. Ralph) is a felt guru. His data can be found here (on his web site):
    http://www.speakerdesign.net/felt_am...ltssenter.html
    (One has to click on the table entries to see the graphs.)
    Oct 2008
    near Rochester, NY
    1,602
    http://www.zaphaudio.com/mtg-surface.html
    Always better to review the data before posting...
    "Never, ever surface mount a 4" flange tweeter. Other than that, you have a little flexibility and your choice of driver mounting is mostly influenced by looks and acoustic center issues. Even those issues are minor."
    Mar 2010
    North Texas, USA
    3,122
    Ain't that the truth.
    I always like to check the source before I quote. That way, when my foot goes in my mouth I can say I did it on purpose.
    Quote Originally Posted by fbov View Post
