Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: wt3 help
    Aug 2008
    council bluffs iowa
    5,735
    Default wt3 help
    installed wt3 on my win7 machine a bit ago and its giving me a fit. when i run the test lesds test it say it cant because the load is more then 1 ohm. when i installed it on the same comp with xppro, it worked like a dream. calibration test with 1k ohm resistor i shows 4k!
    "Listening to music is perhaps the greatest and most profound source of happiness i have ever known. As soon as that music starts, every dollar becomes well spent, time becomes precious and there is no place i would rather be." Henry Rollins stereophile. august 2011
    Jun 2008
    Central Kentucky
    752
    Default Re: wt3 help
    Have you downloaded the most current version on WT3 from DAYTON.COM?
    Did the trick for me when I moved to Win7.
    Ed
    ___________________________________________
    If "IFs" and "BUTs" were candy and nuts, everyday would be Christmas!
    _____________________________________________
    My WebSite
    Aug 2008
    council bluffs iowa
    5,735
    no ill go see. thanks.
    Aug 2008
    council bluffs iowa
    5,735
    looks like i already have ver 2.0 i have checked my settings. 2cn 16bit 44100
    level 1
    Aug 2008
    council bluffs iowa
    5,735
    now im thinking it wont work with 64 bit! great!
    Oct 2008
    Sweet Home Alabama (Roll Tide!)
    1,070
    I've had that same error before. I don't know for certain what corrected it, but I went through the whole installation/setup process and it cleared up. You need to make sure that you follow the directions for the specific version of Windows you're using.
  7. #7
    Aug 2008
    council bluffs iowa
    5,735
    now my duel boot win7/xppro wont start xp which is where office. its just gettin better
  8. #8
    Oct 2008
    1,070
    Quote Originally Posted by arlis_1957@yahoo.com View Post
    "Duel" boot...is that anything like dueling banjos?
  9. #9
    Aug 2008
    council bluffs iowa
    5,735
    No
  10. #10
    Jun 2008
    Central Kentucky
    752
    I'm just running Version 1.5.0, works for me in Win7 just fine.
    Ed
    My WebSite
  11. #11
    Hi:
    Running version 2.0.0 in Windows 7 x32 (32-bit). It's run pretty much flawlessly since I installed it.
    Brainer
  12. #12
    Nov 2006
    New Hampshire
    5,698
    I find mine won't give a good reading unless it's had a full minute to warm up.
    Also check the leads, inside the case. Mine came through with a cold solder joint on one that I had to fix before it would work.
  13. #13
    Aug 2008
    council bluffs iowa
    5,735
    the first one i got was dead in the water. this one worked fine when asked under winxp. i suspect that i plugged it in before the software intall completion and windows asumed it was a speaker and installed drivers in a flash. tomarrow i will restore it to an earlier time and try again.
  14. #14
    Aug 2008
    council bluffs iowa
    5,735
    i ran system restore to the 3rd and reinstalled and made the correct setting in windows. same results. is it possible that it being plugged into a hub could be the problem? it is a powered hub.
  15. #15
    Arlis, that is possible. There has been some talk about using the same USB port every time you use the WT3, and if there are other things plugged into the hub... maybe.
    Also, what is this version 2 software of which we speak? Where is the download link? Is this a free upgrade?
    http://www.youtube.com/watch?v=j9jROjFPAis
    Why you should never support dog shows or breeders
    http://www.facebook.com/GcfCustomAudio
    Facebook
    My Website, a work in progress.
    "When a true genius appears in this world, you may know him by this sign, that the dunces are all in confederacy against him." -Jonathan Swift
    "Sure, the placebo effect is real - but there ain't no sugar pill gonna cure cancer."
    *Gort
  16. #16
    OK, I found the upgrade page and I don't know if the $20 is worth it (to me for basically rub and buzz detection?) plus I do not know what constitutes proof of purchase on the internet... Mine was also purchased before Jan 1, 2011 so does that mean I cannot upgrade to the newest version anyway? Hmmm.... seems a new thread is in order for these questions.
    Facebook
    *Gort
  17. #17
    I mean, the rub and buzz feature is a killer inclusion, but I am not in a production environment. The LCR measurement capability in the new version though...
    Facebook
    *Gort
  18. #18
    Aug 2008
    council bluffs iowa
    5,735
    Quote Originally Posted by johnnyrichards View Post
    If it ever warms up you will be.
  19. #19
    I contacted Sharon @ support@trueaudio.com gave her my customer no. at Partsexpress and she emailed the latest version no charge. WT III never worked right for me on the PC it was installed on, this cured everything ( not my allergies ) and appears to give repeatable readings very quickly.
    Rich
  20. #20
    true dat
    Facebook
    *Gort
