DOTD - Emm-6, How do I use it?
Anyone familiar with how to use this mic to do measurements? I never bothered to get measurements, but it's pretty cheap on sale. I need a PC interface to plug this mic in correct? What software do I use to record and how do I use the calibration file?
Re: Dotd - Emm-6
 Originally Posted by mintos
Anyone fimilar with how to use this mic to do measurements? I never bothered to get measurements, but it's pretty cheap on sale.
You'll need a mic preamp with phantom power. A number of sound cards are available with appropriate XLR mic inputs and phantom power (M-Audio, Tascam, etc.). You can also use a mixer like the Behringer Xenyx series to feed a line input into your sound card.
Herb at Cross Spectrum labs does custom cals and has measured a large number of the EMM-6 mics. While he provides many more correction points, he says the downloaded factory cal from P-E should be close enough for most. He also provides calibrates down to 5Hz and will provide cals for 0°/45°/90° mic orientations while the P-E cal is presumed to be on axis 0° and only goes down to 20Hz.
I went with the full Premium+ package from Herb...the biggest difference between his cal and the P-E cal was a more precise location and shape of the 13-15kHz peak that seems common to these 1/4" mic capsules (see the stock Panasonic WM61 datasheet for an example).
-Brent
Re: Dotd - Emm-6
So, if I wanted to run one from a laptop, what would I need to order along with the mic (I'm looking for "budget-priced" items, if possible)?
This amp?
Amp
Does PE sell one that would work?
Would I need a cable too?
Mike
Mike Jennens
Proud to be a Speaker Geek!
Bismarck, North Dakota
Re: Dotd - Emm-6
This amp?
Amp
Mike
This:
http://www.amazon.com/M-Audio-Audio-...217989&sr=8-12
would probably work a bit better than the "tube" preamp. You will need an xlr cable. You plug the output of the preamp into your laptop and/or an amplifier.
HTH,
Re: Dotd - Emm-6
When I started my set-up, I bought a Rolls MP13.
http://www.parts-express.com/pe/show...20%20&FTR=mp13
I mention it because I sent it to Herb along with my mic so he could check its freq. response. It measured so flat, over such a broad range, that Herb didn't bother with a cal file.
Re: Dotd - Emm-6
I am considering more and more the "Blue Icicle" solution of which Mr. Fitzmaurice is an avid proponent. I have the Dayton mic, the 502 Behringer mixer, a soundcard and an amplifier. Setup is a drag for a few minutes of measuring.
Re: Dotd - Emm-6
^ for ease of use, that's the best route to go. Plug it in, plug your mic in to it, record. Couldn't be simpler.
http://techtalk.parts-express.com/sh...=1#post1727256
Re: Dotd - Emm-6
Anyone take distortion vs frequency and level measurements on the suggested preamps? Wondering whether they can be used for harmonic distortion as well as FR sweeps?
Louis
