Results 1 to 19 of 19
    Nov 2010
    ORegon Coast
    30
    Default Harman Kardon Clearance Subs
    Got a harman kardon email for a clearance sale (http://www.harmanaudio.com/search_br...m_campaign=em2)
    Was looking at this sub wondering if it's any good for the price.
    http://www.harmanaudio.com/search_br...000CHR&status=
    The sub I have now is a bandpass 12" ported ported for 50hz and has very little spl below that, and very sloppy sounding above that.
    I like the idea of a tightly packaged commercial sub, although I've been considering building my own to go with my zaph za5.2 l&r & 5.3 center
    I'm sure there is compromises, but for less than 300? Can't seem to find many reviews good or bad.
    thanks!
    Default Re: Harman Kardon Clearance Subs
    Quote Originally Posted by 707kevin View Post
    thanks!
    You could build one hell of a sub that can extend down to the high 20's/low 30's for under $300.
    Definitely build your own!
    A CSS Trio 12 in a vented box and a good plate amp will impress you.
    A comparable DIY amp alone will set you back what that entire subwoofer will cost. The driver is also high quality in that unit. Probably the only thing that would need work is the cabinet, but even then it is probably cross-braced and glue-blocked so any improvements will be minimal.
    Is it worth it at the so-called list price? Not a chance. At under $300 shipped to your door? Can't be beat.
    Facebook
    *Gort
    Ohio
    960
    Be careful, I believe this sub is meant to be used with the small Infinity satellites. If you look, it says the crossover is fixed at 150 hz, which is bad news:
    Crossover Frequency 150Hz, 12dB/octave
    Quote Originally Posted by christianb View Post
    That is a deal breaker for some 2.1 music setups, but for a HT setup the subwoofer crossover can usually be left on a high setting anyway and let the processor's bass management handle it.
    Facebook
    *Gort
    Ohio
    960
    Didn't think about that!
    If I'm looking at the correct owner's manual: it appears the LPF@150Hz can be defeated with a switch on the back panel.
    Dec 2009
    Houston, TX
    702
    I have a good DIY sub but Johnny's right, you can't touch that in DIY for $300. Just a 300 watt bash amp and a decent 12" and you are well over $300 without the RABOS system and then you still have to build a box. The RABOS system is a great plus also, it automatically takes a measurement and will notch out a few offending peaks. It makes placement much easier.
    My 2 cents worth anyhow.
    Nov 2010
    ORegon Coast
    30
    Thanks for the feedback. I'll see if they still have any in a week... I just bought all sorts of junk for the jeep.
    150hz is no problem for me, I use the avr settings for that.
    thanks again!
    Jan 2009
    Ottawa
    1,079
    thanks!
    Would you happen to know if these are shielded? If they are, one goes on my shopping list. Unless they have a flawed design (which I doubt), they're a steal at that price.
    Nov 2010
    ORegon Coast
    30
    This page says yes. Grab me one while your at it!
    http://www.bhphotovideo.com/c/produc...Subwoofer.html
    Quote Originally Posted by DDF View Post
    Yes they are. I had one of the drivers they used in that subwoofer series, and it uses a bucker but no cup.
    Facebook
    *Gort
    Jan 2009
    Ottawa
    1,079
    Oof:
    http://www.harmanaudio.com/site_info/outside_us.asp
    Dang isolationists. ;-)
    Oh that's no fun, those scurrilous hosers. I am flush on subwoofers, or I would buy one of these. Sorry about your luck, eh?
    Facebook
    *Gort
    Creedmoor, NC
    870
    I am always so skeptical of rated specs, because of that I would have trouble justifying this. I don't believe it puts out 400 watts, and I would doubt the low freq rating. So taking my skeptic nature in to account, I am a builder in this one. You can get a Dayton reference 12 and a Bash 300 for under $300 @ your door. And you will not be disappointed.
    Quote Originally Posted by AMC View Post
    Actually, it does get close to what is claimed. Plus, it has a nifty parametric EQ package that the cheap BASH does not.
    In fact, the amplifier has some equalization built in, including a bass boost, high pass and a broad notch filter all to tame some of the peakiness from the highish Q alignment.
    I had a service manual for the unit at one time when I procured the driver used in this. I could not duplicate their product for what it would cost me to buy it today. At a minimum it would require one of those BASH amps floating around with the parametric EQ.
    Facebook
    *Gort
    Aug 2009
    Ohio
    1,063
    Infinity used to make some really serious subwoofers. I have a pair of Infinity Perfect 10 VQ, weighing about 25 lbs each with 16 mm linear travel one-way. They are a beauty to look at. I should have put them into Plexiglass enclosures BTW. The deal on $300 also includes free shipping?
    Jan 2009
    Ottawa
    1,079
    Thanks for the help regardless. I'm sure I'll turn something up or just build one
