Results 1 to 6 of 6
    Default Working with PVC Molding?
    ..related to my Big Bonehead Array..
    I'm building tall speaker grilles (7.5' x 8") out of PVC 1/4 round molding. I couldn't find a single straight piece of wood molding at Lowes.
    Has anyone worked with this stuff. I'd like to just use glue to assemble the parts, and I bought PVC (pipe) glue, assuming this would make the best joint, but I'm worried the glue might be too "aggressive" and just melt the material. I could try gorilla glue, or even wood glue - not sure. Any other suggestions??
    If no one has any experience, I'll try a few test joints and report back.
    Sep 2010
    Canton, OH
    1,556
    Default Re: Working with PVC Molding?
    Loctite PL Premium in the caulking tube will do the trick...it can be messy though
    Aw heck..back to Lowes. Thanks for the tip.
    5,785
    Quote Originally Posted by chad1376 View Post
    Try it on a test piece.
    Oct 2006
    Manchester Mo
    753
    I use PVC trim outdoors. Usually use nails and latex caulk. Don’t use PVC glue between PVC and wood it will not hold. PVC to PVC is OK. If this joint is bewtween wood and PVC it is going to show, even indoors because of the difference in expansion and contraction. It's also going to take finsh different than wood.
    Oct 2006
    Manchester Mo
    753
    Re read the post yes PVC glue works use heavy body if you can find it make sure you use PVC cleaner. I'm a bit anal so I roughed up piece I was joining.
